It is currently Mon May 04, 2026 8:14 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cases
PostPosted: Thu Jan 28, 2010 5:24 pm
I went with an engle 120 with 1.25 rockers it seems like the best of both worlds to me i have plenty of low and top end. I am anxious to blast a few more hills I didn't get to ride a whole lot after the motor was finished
PostPosted: Tue Feb 02, 2010 11:34 pm
what block would be best to build a 2054 or 2176?
PostPosted: Tue Feb 02, 2010 11:48 pm
a good as41 case. just look on side of oil pan should say as41 .
PostPosted: Thu Feb 04, 2010 10:34 am
Alumnium case 19 pounds heavier than AS41!
PostPosted: Sat Feb 06, 2010 12:07 am
Seriously? 19lb's. Wow. That's interesting,if your worried about wieght. Personaly, I want safe, reliable but with a lot of nuts and ready to rip. First thing is to finnish it, check it out, then figure out where I went wrong. Dave W.
PostPosted: Sun Feb 21, 2010 9:07 pm
[/quote] They guy that built mine (Lewis) has been building motors for a long time and he just does not build it, every one is balanced and blue printed. Lewis is like the Godfather of vw motors. [/quote]
so how does someone get a hold of a good engine builder? i want a 1915 in my stock block but want it to rip with a w/c 6 rib turning 33 cut boggers.. plan to go dry sump too...
seems you cant build a good motor on budget so that is out the window just want good power that'll take being rode hard and put up wet for many seasons...
PostPosted: Sun Feb 21, 2010 10:19 pm
Call Drews southern buggy davis . some of the sponsors biuld some bad a?? engines . Its the litte things that make the tq& hp . 6 rib & 33 tires 1915 port the heads small cam like w110 - c35- fk 41-42 & 11.1 cp . you will have a hard time biulding tq in a 1915 for 33 & a 6 rib
