It is currently Sun May 03, 2026 8:22 am
 Post subject: Alternator KIT??
PostPosted: Sun Jan 31, 2010 7:20 pm
I want to switch to an alterator so i have been looking for a kit but all the parts in the kit say will work on both. so can i just buy the Alternator, or do i need a kit. Is there something im missing here. thanks guys
also what do you guys think about this one
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
thanks
 Post subject: Re: Alternator KIT??
PostPosted: Sun Jan 31, 2010 8:02 pm
You'll need a pulley for the altenator.
PostPosted: Sun Jan 31, 2010 8:13 pm
I know I bought a bosch Alt for my 1600 that used the stock pully. I just had to add a light. Not sure on the numbers.
PostPosted: Sun Jan 31, 2010 8:50 pm
so the stand will work ok and i have to buy a new pulley mine is bent.
PostPosted: Sun Jan 31, 2010 8:53 pm
I think you need a different stand now that you mention it.
PostPosted: Sun Jan 31, 2010 9:28 pm
i converted last year and nitro is rite with a bosh the stock pulley will work but you need a new stand
lets just ride
PostPosted: Sun Jan 31, 2010 10:25 pm
Thanks, been about 4 yrs since I did it. Wasn't 100% sure :?
PostPosted: Sat Feb 27, 2010 10:43 pm
you will have to change the stand and buy a new pully.i bought my alternater at o'reilly's auto parts for $100 with a lifetime warrenty.they will have to order it but they can get them.i paid $100 for the alternator and $10 for the pully and $5 for a good used stand.it's really easy to change to an alternater.ill never use a genrator again.
PostPosted: Sun Feb 28, 2010 7:46 pm
sorry but (stand yes) pulley no! stock pulley will work,i am still useing stock pulley!
lets just ride
PostPosted: Sun Feb 28, 2010 9:24 pm
I have been looking into converting mine over these are the most complete and low priced setup I have found.
natural finish $139
http://www.socalautoparts.com/product_i ... 3d1fa0c609
Chrome finish $159
PostPosted: Mon Mar 01, 2010 7:42 am
if your useing a stock fuel pump you may heve to change it & the fuel pump rod .
kenny ( AKA D.O.G. )
PostPosted: Wed Mar 10, 2010 10:44 pm
i got the Natural 75 Amp from ebay and i ordered a new stand tue. So sometime next week we will see about the fuel pump bc i was looking at that today it will be close.
and the Alternater $80 shipped and the stand for $12 :lol:
PostPosted: Wed Mar 10, 2010 11:40 pm
i switched from gen to alt on my first vw eng and changed only the stand.
PostPosted: Thu Mar 11, 2010 12:32 am
When I switched over, my fuel pump was fine but you need to be careful because the fuel pump rod for a "Generator" motor and an "Alternator" motor are different sizes. Just remember, you still have a "Generator" fuel pump rod even though you are now running an Alternator.
PostPosted: Mon Apr 05, 2010 8:59 pm
i just got it all on today, but the arm on the right side of the carb hits the alternator do i need a spacer or what do i need?? THANKS
PostPosted: Mon Apr 05, 2010 9:50 pm
If its not a common problem a picture may help explain this.
PostPosted: Tue Apr 06, 2010 12:25 am
Some company used to make an aluminum spacer to offset the carb to the drivers side a little. Not sure who has them, havent seen one in years. Maybe turboblue can find out.
PostPosted: Tue Apr 06, 2010 7:20 am
i no every ones difrent but i had one that did that, i just ground a little off the alt.
PostPosted: Tue Apr 06, 2010 8:21 pm
i got it somewhat i made a spacer about 3/8 and had to bend the arm just a little. here are before pics
:evil: :evil: NOW ONLY IF I CAN BLEED THE BRAKES :evil: :evil:
PostPosted: Wed Apr 07, 2010 9:39 am
tried this??:
http://www.woodsbuggy.com/index.php?opt ... =10&t=8652
PostPosted: Wed Apr 07, 2010 3:49 pm
we alwayys just ground down the alt to clear. they have quite a bit of thickness to them.
