It is currently Mon May 04, 2026 12:36 pm
 Post subject: bolted rockers
PostPosted: Fri Dec 25, 2009 11:06 pm
One down and one to go , man this sure is alot a work just hope its werth it.
 Post subject: Re: bolted rockers
PostPosted: Fri Dec 25, 2009 11:10 pm
WOW,,those look aggressive,,,how about some more pics :wink:
PostPosted: Fri Dec 25, 2009 11:16 pm
oooow aaahhhh ! :idea: the wife wants some studded tires for her van , are you takin orders :!: :lol:
PostPosted: Fri Dec 25, 2009 11:22 pm
Gonna start on the other one tomorrow ,I'll get some more pics,
And no orders here this is to much like work lol..
PostPosted: Sat Dec 26, 2009 10:23 am
Bolted tires is like putting tracks on a skid steer loader,Claws on a cat,Like putting it in 4 wheel drive
Back 25 years ago A friend of mine was working in Ohio and stopped off at Cromer Ridge KY with a set of Buckshot Bolted 'P' hadn't no body ever seen anything like his whole buggy .It had 3x3 ,930 ,bolted tires ,Built 091, 2276 When every one else there was in swing axel buggys funny how things change
PostPosted: Sun Dec 27, 2009 5:40 pm
did those tires work well before bolting? They dont look like they are real aggressive, but it may just be in the pictures.
PostPosted: Sun Dec 27, 2009 8:28 pm
There not as aggressive as a cut bogger , alot shorter lugs. But they are soft and lighter than a bogger so i'm hoping they'll do pretty good with the studs . And i've still got some cutting to do ,but the pics don't do them justice I'll get some better one's up soon..
PostPosted: Sun Dec 27, 2009 10:14 pm
WB I got a set of 42 TSL cut and bolted for sale....new
PostPosted: Mon Dec 28, 2009 9:03 am
So that is who they were telling me about. :shock: I was wondering who dug all the ruts in there. :shock: :shock: All the guys that were there said they thought he worked for the pipe line company. :twisted: :lol: :lol: :twisted:
PostPosted: Fri Jan 15, 2010 7:20 pm
Finally got the beadlocks and tires on and ready to try them out tomorrow , heres a few pics.
PostPosted: Fri Jan 15, 2010 7:29 pm
Wicked
PostPosted: Fri Jan 15, 2010 8:00 pm
WBSOUTH, hows that new setup working for you, the chaindrive part. Did it transfer the weight like you wanted?
PostPosted: Fri Jan 15, 2010 8:37 pm
Don't Know yet first ride tomorrow with the chaindrive another than around the field here at home. I think it'll climb great as long as the chaindrive setup will hold up and if the sprocket ratio is right ,we'll see.
PostPosted: Thu Mar 11, 2010 7:22 pm
whats size bolts are you running or does anybody know ? thanks jason
PostPosted: Thu Mar 11, 2010 7:46 pm
Wow bolted tires look insane. :shock:
What are those rims? Are they aluminum drag rims by any chance? My old mans got some that look just like that on the back of his hemi street rod. Those rims are some heavy sob for being aluminum.
PostPosted: Thu Mar 11, 2010 8:10 pm
Well Bruce it hooked up good.
PostPosted: Fri Mar 12, 2010 7:18 pm
I used a 1/2 inch carriage bolt with a 5/8 washer on the inside ,and 1/2 inch washers and nuts on the outside then welded the top. the trick is to drill a small hole in the tire then go on the inside with a drill and tool to hold the bolt and drive it threw with a little lube and alot of elbow grease. then put them on the wheel with some slime and your good to go.
The wheels are aluminum with home made beadlocks,i got from summit racing, can't remember the brand.
Thanks nittro, I'm finally pleased with it and the way its hooking up, it's about time lol..
PostPosted: Fri Mar 12, 2010 7:37 pm
Im sorry RR but i doubt Lewis,Greg and Clayton were running swing axles and 1600's except for Greg,he was running a 1600 DP with drilled valves.
PostPosted: Fri Mar 12, 2010 8:32 pm
Well no new ideas ever seem to work perfect the first run. Some times a little tweeking is needed, looks good and seems pretty balanced now. I'm sure it made Clayton happy :mrgreen:
PostPosted: Tue Jun 01, 2010 9:14 pm
please dont run me over im scared of them i might do that to my boggers when i get some u think its worth it
PostPosted: Wed Jun 02, 2010 1:02 pm
You should really only do it with an auto tranny, cause it has some slippage and it can have insane bite without hurting anything. With a 6 rib, 3 rib, whaetever you run if it's a manual, it has no slip, so your tires need to be able to spin a little bit to help prevent breaking joints, diffs, ring and pinions, etc. So pretty much, only do it if you run an auto. It can be done with a standrard trans, but it's risky.... and you WILL break stuff. Just my $.02. :D
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
