It is currently Sun May 03, 2026 12:38 pm
 Post subject: fuel cell quesitons
PostPosted: Tue Jan 12, 2010 11:12 am
I am doing a w/c swap soon and im wondering the cheapest way to step into a fuel cell or modify my tank to work. I have a round poly and was wondering if i could just sink a pump and sending unit into it so i wont have to use an electric aftermarket pump and regulator? or do i need to get a cell?
 Post subject: Re: fuel cell quesitons
PostPosted: Tue Jan 12, 2010 11:30 am
There a lot a answers to this question. When I did mine I felt I needed more weight up front to counter the added weight in the back so I bought a 5 gallon fuel cell and mounted it up front. Five gallon is enough fuel for an EFI engine . I was also running into space issue with the lager engine, radiator, larger oil filter, etc. in the back so it helped free up some space in the rear area . I use an inline EFI pump and clear plastic filter,,kinda like the VW fuel filter just a little bigger. My pump is mounted closer to the engine than the fuel cell. This set up works for me,,,,,for now :wink:
It may depend on where you have room. You may decide to use your poly tank and leave it where it is. You may need to add a return port to the tank. EFI needs to return fuel to the tank. Good Luck. :wink:
PostPosted: Tue Jan 12, 2010 11:38 am
So you run an inline pump? wtb a regulator?
PostPosted: Tue Jan 12, 2010 11:46 am
I am not sure about the regulator,,I think EFI engines need the big pressure of an EFI pump and the regulator is built in somehow if it even has one. The return line allows the residual fuel to return to the fuel cell,,or low side of the pump.
PostPosted: Tue Jan 12, 2010 2:43 pm
get a booster pump off a 80's-90's ford truck thats what i use its a inline pump. mount it close to the fuel cell. it pushes better then pulls.
PostPosted: Tue Jan 12, 2010 9:21 pm
The return dosen't have to go back to the cell. Put a T in a little before the pump, that will take care of the return fuel.
PostPosted: Tue Jan 12, 2010 11:52 pm
that's a good idea :idea:
PostPosted: Wed Jan 13, 2010 8:01 am
It might work but don't the fuel need to cool,,,thought that might be the reason for going into the tank,,maybe not,,,you taught me something.
PostPosted: Wed Jan 13, 2010 9:37 am
This is the way I have mine done and no problems yet. I have ran both very hot days and very cold days. Beats drilling and tapping the fuel cell.
Bryan
PostPosted: Wed Jan 13, 2010 11:35 am
i think i may just take the tank from the van and make it smaller to fit.
PostPosted: Wed Jan 13, 2010 11:37 am
Sounds dangerous,,,be careful. The T on the low pressure side of the supply line may be the simplest fix :wink:
PostPosted: Wed Jan 13, 2010 1:05 pm
altering a used gas tank is possibly one of the worst ideas ever.
PostPosted: Wed Jan 13, 2010 4:20 pm
thats what i'd end up doing. Where did you get and what pumps are people running? i'd like to keep my poly tank (very low cash to play with) but idk if ill be able to do it with the poly.
PostPosted: Wed Jan 13, 2010 5:39 pm
Here is another thread to look at ----> http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=17&t=3648
PostPosted: Wed Jan 13, 2010 6:48 pm
So i was jsut looking at inline fuel pumps, and boy are they EXPENSIVE! How did you guys do your gas lines? stock stuff or did you fabricate it? I'm sorry im asking so many questions about so many things, but i have no clue how im going to attempt this, let alone pull it off and have everything work. :oops:
PostPosted: Wed Jan 13, 2010 7:07 pm
i have well had a poly tank on my buggy and was ok with it untill i had a few guys tell me about how unsafe they are and one story was about how a guys new buggy caught fire because of one , i took there advise and its gone , point is i would listen to these guys on safety for sure !!! one short cut that should not be taken is the fuels safe haven !
PostPosted: Wed Jan 13, 2010 7:20 pm
you can get an aftermarket inline pump from any autoparts store for like $40.00
PostPosted: Wed Jan 13, 2010 9:39 pm
A $40 pump that can do 60 psi fuel pressure, where at Jeff?
PostPosted: Wed Jan 13, 2010 9:55 pm
thought the ones they made for carbed engines they also made for f.i. engines, i am probably wrong, my bad.
PostPosted: Wed Jan 13, 2010 10:38 pm
Ford F150 fuel injected trucks from the 89-93 model years are Delco EP286. This is what I have been running on my buggy for 2 years now.
Check out this link for a picture ---> http://www.megamanual.com/v22manual/minj.htm#supply
Huey
PostPosted: Wed Jan 13, 2010 10:47 pm
i took a fuel pump off of a jeep wrangler sending unit once and ran it as a inline pump it was a trail fix and i never had a problem with it and ran it for months ! :oops: ( why fix it if it aint broke )
PostPosted: Wed Jan 13, 2010 10:53 pm
I went to a salvage yard and got a pump off a v12 jag works great on suby for 25 bucs.
PostPosted: Wed Jan 13, 2010 10:58 pm
another option,,what I use
http://cgi.ebay.com/ebaymotors/MSD-INLI ... ccessories
PostPosted: Wed Jan 27, 2010 11:08 am
I have a race legal 12gal foam filled fuel cell that I only used for a year that I'd sell for around $100.
PostPosted: Thu Jan 28, 2010 2:24 pm
Yes, it is a very bad idea ....unless you take the proper steps.
We have repaired many steel fuel tanks at my work. Empty it completely, let it sit over night opened up as much as possible (filler cap off and sending unit door removed) with a fan blowing across it. The next part sounds crazy but it works. Run a shop exhaust hose (small dryer vent hose might work) from the exhaust pipe of a truck (or other larger motored vehicle) into the tank. Let it run in there a few minutes, and leave it idling while you weld, grind, cut or whatever. The CO from the exhaust is inert , and it will push out any 0xygen present so there is no way for ignition to happen.
(we do still do this outside, just in case, and to avoid asphyxiation :roll: )
Disclaimer: The author of this post and/or this website or its administration assume no responsibility for the safety of anyone attempting the above repairs or their actions due to their lack of ability to follow directions .
8) :twisted:
