It is currently Sun May 03, 2026 6:57 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jan 05, 2010 12:56 pm
If I am picturing this right, it puts power to the outside wheel becase that is where the resistance/weight is located. So it should turn good without cutters compared to a posi setup. But you will need the fronts to do all of the control, I think. I think you will like it on trail riding, but the front gets lighter on hills. If it's going to cause a problem this is where it will happen. I wouldn't think it would work good on KY goat trails. But Wellsville is a different animal. I don't THINK you will like it, but won't know untill someone tries it. And like I stated before, you two have heavy buggies, which gives you much better weight on your fronts then a little KY single seater. If it's going to work for anyone it will in that style of buggy, lol, I THINK!
PostPosted: Tue Jan 05, 2010 1:46 pm
Going downhill or letting off the throttle in a turn is not a problem. It will work in those senarios. Its when you are on the throttle that will not work. I suspect if your a little on the throttle you can use the Cutter brakes, however the harder your into the throttle the more locked the diff becomes, making the cutters actually lock it even more.
rockrockets1 wrote:
Larry this is my feeling also ..I don't think this will work ..nothing like coming down a hill headed for a tree slow and trying to turn to go around and drive strait in to it
PostPosted: Tue Jan 05, 2010 1:49 pm
I am with you on all counts and that is why after finding out the new info I have not released th check for the Diffs. They are on hold pending decision.
kybuggy1 wrote:
If you cant use the cutters when under power, how you gonna climb?? How you gonna spin around tight corners, or a tree, or any obstacle? I understand how it works, and think the traction would be the shiz in a street/drag car, but in the woods, where turning tight and quick is what its all about...I dunno. You guys like to fast trail ride right?, do you not use your cutters to do this?? Not criticizing, just confused.
PostPosted: Tue Jan 05, 2010 1:57 pm
In talking with Sherman (Peloquin user) he just powers his buggy in the turns and it works well for him. As you stated the Diff tends to put more power to the outside wheel in a turn. An open diff does a similar thing in that in a turn it tends to let the inside wheel spin slower and the outside wheel spin faster adding power around the turn. Unless the Peloquin puts most of the power to the outside (acting like a cutter brake would ) it would not be much different than an open diff in that regards.
PostPosted: Tue Jan 05, 2010 1:59 pm
Maddog can you get Sherman to join this discussion? I think it would be prudent to have him on board. It appears we have more than a few Interested in this diff and would like to also know if its worth changing out the atiquated open diff.
PostPosted: Tue Jan 05, 2010 4:33 pm
He really doesn't have a computer, just one of those web tv things.
I called him, he's gonna try tonite.
PostPosted: Mon Jan 11, 2010 10:08 pm
so what have we decided steve?
PostPosted: Mon Jan 11, 2010 10:52 pm
I'm not sure ,,but I think a person could learn to drive a buggy with this type diff. I really like the way you can hobble back to camp with one axle. But it is way back on my wish list,,,,,,for now :wink:
PostPosted: Tue Jan 12, 2010 11:20 am
Its still in the Works. We are going to start with one and do some field testing to determine if in fact they are a viable alternative for us Woodsbuggy Owners.
PostPosted: Tue Jan 12, 2010 11:32 am
Great Ody,,,thanks :wink:
PostPosted: Wed Jan 13, 2010 11:24 pm
i went into live chat and looked at previous convo, and your boy sherman was in there, i don't think he realized to come to the forum and not the live chat. he was looking for eric? is that you maddog?
PostPosted: Thu Jan 14, 2010 12:16 am
Nope,I'm Bill.
Don't know who eric is.
PostPosted: Sun Apr 11, 2010 3:07 pm
hhmmmm.... i see some one spent a few dollars and bought one of these...it looks really stout... :lol:
PostPosted: Mon Apr 12, 2010 8:54 am
how bout some feedback! Was it worth it?
PostPosted: Mon Apr 12, 2010 9:39 am
its ody's.... i just got to ck it out when i dropped my trans of to get built....i dont honestly see anyone breaking one anytime soon that for sure
PostPosted: Mon Apr 12, 2010 9:46 am
Yep that be mine. Had Brian put all new Weddle close ratio gears along with the LSD. Don't know when I will get to test it due to to many projects I have going. When I do I will post its performance. I had bought another midshift so i would not have to take the one out of my Buggy for the build. So when i get the time I will swap them out. Now if someone was to volenteer to come to do it I would be eternally grateful lol.
PostPosted: Mon Apr 12, 2010 8:19 pm
if you can wait till next winter I'd be happy to help ya
- Sigmund Freud
- Antonio Meloni
PostPosted: Mon Apr 12, 2010 9:08 pm
bring it to wellsville,we changed firebugs out when his broke.not wishing you any bad luck but if yours does go out you'll have plenty of help with the change.chad :mrgreen:
PostPosted: Tue Apr 13, 2010 4:09 pm
Sure feels like next winter outside to me. Your not here yet?
PostPosted: Tue Apr 13, 2010 4:12 pm
Yea I know , I was there. Something about working in the dirt during a Buggy dust storm just does not appeal to me! :roll: :mrgreen: I like things like a floor and jacks, jack stands, air compressor and air tools. And did I mention lights? etc.
PostPosted: Thu May 01, 2014 10:20 am
Did you ever get to test the differential, how did it do?
