It is currently Mon May 04, 2026 1:57 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 21, 2009 12:23 am
Odyknuck wrote:
That looks pretty good Brad. Did you remember to prep the PVC before you painted it so it would stick? BTW is your new screen name now gonna be hillaplumber :P :mrgreen:
Yeah I scuffed it up and used plastic paint. I painted it outside and 1hr after I painted it started raining :evil: . After doing this I should be able to plumb my house. :D
PostPosted: Sat Mar 21, 2009 8:20 am
nice work
PostPosted: Sat Mar 21, 2009 9:00 am
i think he picked up a can of plastic spray paint on one of many trips to lowes (looking for the right pvc fittings)
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Mar 21, 2009 9:32 pm
this is what i did .083 wall aluminum tubing 3" od matched the od and the outlets on my air cleaners
PostPosted: Sun Mar 29, 2009 10:37 pm
http://www.woodsbuggy.com/botm/jan09/rear.jpg
How about this setup? That is what I am running and no problems at all it runs very strong at all rpm's and not even starving for air at all. Good job on your airlogs, u will have no problems at all with it, by the way, what size motor are you running? If it is a 2276cc, the 2" pipe may be too small and will affect the performance of the motor, I know this for a fact that it did'nt work for me until I went larger diameter and it really is a huge difference on how mine ran.
PostPosted: Mon Mar 30, 2009 1:56 am
It's a 2332. I hope it works but if not it's only $20 in pvc. I haven’t ran it yet so I don't know. What did you notice with the smaller tubing? Should I just go to 3" pvc?
PostPosted: Mon Mar 30, 2009 5:58 am
It ran like it was getting too much fuel and not enough air and also blowing alot of black smoke as well, went larger and man what a difference! I went from 2" PVC that has a 1-3/4" ID to a 2-1/2" aluminum bored out .125" over to make it 2-5/16" ID
PostPosted: Tue Dec 29, 2009 2:04 am
where did you get the filter at and how much i am building the same intake but cant find a canister for a decent price.
hillaholic wrote:
I’m starting to figure out the install of my industrial air cleaner set up. I need to figure how to mount the air box because it didn’t come with any mounting. I have some round gas tank straps I think will work. I hope this is ok. Do I need to worry about the T not being in the center? What do you guys think so far?
Plumberpill are those the street 90’s you were talking about?
PostPosted: Tue Dec 29, 2009 9:47 am
Subysteve found mine on craigslist. Search Donaldson filter
one on there now
http://cleveland.craigslist.org/for/1523778028.html
PostPosted: Tue Dec 29, 2009 9:50 am
also they sell UMP knock offs at http://www.mooreparts.com just search air filter there. They cost around $150 for new aluminum.
PostPosted: Wed Dec 30, 2009 9:34 am
http://www.enginaire.com/prod03.htm
- Sigmund Freud
- Antonio Meloni
PostPosted: Wed Dec 30, 2009 10:20 am
http://www.samwinermotors.com/ not sure if this will help you but i remember when i picked up my rockwell axles i saw some of those filter there . the filters were off military trucks , i called them and they said 20 to 25 dollars for a unit so if they will work save you a couple bucks and thats what is all about to me !! im going to go there probly this week and ck them out if they will work ill buy one and post some pics only concern i have is the filter replacement later down the road ( the cost) because there off military trucks thanks jason
