It is currently Mon May 04, 2026 6:10 am
PostPosted: Mon Nov 16, 2009 11:15 am
Haven't pulled the tranny yet, 1,2,3,4 all work, seems like I only have half of reverse gear when on a flat surface. Tranny is a 5 rib. I am guessing that I will be replacing bearings and seals, and the reverse gears. Any other suggestions or comments?
PostPosted: Mon Nov 16, 2009 11:44 am
Buy or borrow one of these:
It's for takinig the pinion nut socket loose.
PostPosted: Mon Nov 16, 2009 11:55 am
I take it that it makes the difficult job a whole lot easier?
Would Long Enterprises probably have something like this?
How are Long Enterprises' parts compared to weddle's? price and quality?
Thanks.
PostPosted: Mon Nov 16, 2009 12:09 pm
the 2 reverse gears aint that high,u will probaly need to know how many teeth before u order,dont know,its the tools that are high,,,that 1 tool turbo listed is around 150.00,then u can make the other one to take the bearing holders out
PostPosted: Mon Nov 16, 2009 12:33 pm
The people at Long Enterprise are very helpful and friendly. I have done lots of business with them and have all way received great service and parts. His Used parts are first rate would not even know they were used if he did not tell you. Just my 2 cents worth.
kydecoy
Work Hard Play Harder
PostPosted: Mon Nov 16, 2009 12:49 pm
You can get the pinion socket for $87 here. It's the cheapest I found.
http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=VW381-14&CTMP=1
PostPosted: Mon Nov 16, 2009 10:06 pm
Found out this afternoon the small reverse gear is $70 and the big reverse gear is $250 from Long Ent. Ouch. Alot more than what I was thinking. Will be calling Weddle tomorrow to see what they want. Talked with Eric and will be doing it myself, doesn't sound too hard.
PostPosted: Mon Nov 16, 2009 10:36 pm
i would find a used ones and put in it,if u tell me the count and what type of reverse gear i will look,i got a freind that has a 5 gallon bucket full of reverse gears
PostPosted: Mon Nov 16, 2009 11:34 pm
Reverse from a single side plate car tranny [superbeetle] is the same gear.
Small gear is 15 tooth.
PostPosted: Tue Nov 17, 2009 1:33 pm
That is way too much.
I keep a few of those gears new.
Get a tooth count on both and I can get you a price if you'd like.
The transmission Maddog speaks of is an AT code tranny and came in all Beetles about 73 and later.
Look here for the ID code.
Pad opposite the fill plug and just below the 9:00 position.
