It is currently Sun May 03, 2026 7:32 pm
PostPosted: Sun Aug 30, 2009 1:36 pm
Thought some of you might need this.
http://midmoracing.com/bendit.htm
If you go here http://www.pirate4x4.com/tech/bendin_tube/index.html read the page and then you will know how to mark your die.
PostPosted: Sun Aug 30, 2009 11:20 pm
That's cool. Thanks for sharing that.
John
PostPosted: Wed Sep 02, 2009 5:26 pm
Nice little program. Thanks for sharing!
PostPosted: Wed Sep 02, 2009 5:41 pm
Thanks, nice and simple just what i need.
PostPosted: Mon Nov 09, 2009 3:04 am
Thank's. Just tagged those sites 'caus I just got a model 3 as a early birthday- xmas gift. I'll be ordering a die set in the morning. Finally, I can get to the major frame reworking. Most everything else is ready to be bolted or welded on.
PostPosted: Fri Nov 27, 2009 1:00 pm
When first started twisting tubing I wished I had a program to assist me. But once I found this link and learned how to use it I forgot all about needing a bend program. All you need is a few tools which you should have already and a clean floor to work off of, which in my case I use a sheet of cardboard.
Look around their site have a lot of other good tech info.
