It is currently Mon May 04, 2026 9:33 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Sep 18, 2007 9:09 pm
Something to consider is if you raise your front end even a little with drop spindles is use the ball joint spindle. I did this with a bus ball joint front 8) end and gained about 3 inches . The bus ball joint front end is nearly indestructable. Clean it up and use suspension straps and get a good bit of travel. Make longer arms and get more.
PostPosted: Sun Oct 28, 2007 1:01 pm
I run king kong combos from german auto out of cal they are indestructable
PostPosted: Tue Oct 30, 2007 8:52 pm
Odyknuck, have you had a chance to use them, if so how did they do?
http://www.youtube.com/v/ervaMPt4Ha0&autoplay=1My build up
PostPosted: Wed Oct 31, 2007 8:56 am
Actually I returned them to the Vender. I was told by the vender that I could not get replacement parts so I opted out. I ended up with a set of used Tweeds and rebuilt them to my specs.
