It is currently Mon May 04, 2026 12:28 pm
 Post subject: 1978 bus tranny
PostPosted: Mon Sep 17, 2007 5:38 pm
What would this bus have for a tranny? Would it be side shift?
THANKS, DAREK
PostPosted: Mon Sep 17, 2007 5:41 pm
I'm bettin 5 rib. 486 r&p. See if you can see the ribs. Describe them and some of the experts here can tell you. 8) but I'm also bettin Sharpscooter will know. :?
PostPosted: Mon Sep 17, 2007 5:53 pm
A 1978 bus will have a 6 rib 091 tail shift if it hasnt been changed,3 ribs were somewhere around 68-73 5ribs were 74-75 and 091 6 ribs were 76-79 you get into the side shifts 80 and up I believe the tail section side shifts were 80 -83 and 84 up the shifter was on the mid section of the case, this is info I have found on the internet researching these trannys the past several years,I am by no means an expert just passing along info I have read.If this does not answer your question, pm Roy or Eric Debord they will know for sure
 Post subject: 78 bys tranny
PostPosted: Mon Sep 17, 2007 6:18 pm
I should of gave more info right know. I have a 3 rib tranny hooked to a 2332 i run out of gear real fast . A guy i know needs some money so he called and offerd me his 78 westfalia real cheap. I just dont want to mess with a side shift. Thanks for the help i was hoping it was not a side shift. I will go get it. The price is right.
THANKS,DAREK
PostPosted: Tue Sep 18, 2007 6:15 am
Darek,
Let me know if you want to sell your 3-rib then. Or are you just going to keep it as a spare?
 Post subject: 78 bus tranny
PostPosted: Tue Sep 18, 2007 5:57 pm
Hey jeff my plans changed i just went and looked at the bus its to nice to part out . So i will be leaving the 3 rib in my buggy and driving the bus. If i run into a tranny ill let you know .
DAREK
PostPosted: Tue Sep 18, 2007 8:09 pm
You should put your 3 rib in the bus, and the 6rib in your buggy
PostPosted: Wed Sep 19, 2007 5:54 pm
I thought about that. The only thing i dont know about is when i put the 3 rib in my buggy i had to trim the input shaft down. Would it still work in the bus or do i need a new shaft? or is possible to trade shafts in the trannys? if so would it be pretty simple to do?
DAREK
PostPosted: Wed Sep 19, 2007 8:40 pm
Ask Roy about that,I dont think its that hard to swap,but Roy can tell you how to do it
 Post subject: Re: 78 bus
PostPosted: Thu Sep 20, 2007 4:11 am
[quote='baja1965']I thought about that. The only thing i dont know about is when i put the 3 rib in my buggy i had to trim the input shaft down. Would it still work in the bus or do i need a new shaft? or is possible to trade shafts in the trannys? if so would it be pretty simple to do?
DAREK[/quote]
It will still work even with the shaft cut down. You can easily change the shaft if you wanted to. Simple. Remove bellhousing, take off the snap ring, slide the coupler collar bac
PostPosted: Thu Sep 20, 2007 3:05 pm
Thanks ROY
DAREK
