It is currently Tue May 05, 2026 1:13 am
 Post subject: OIL PUMP COVER ?
PostPosted: Mon Sep 21, 2009 2:25 pm
ok i know this may be a stupid question but here goes anyway.
can you swap out just the cover on the oil pump with one that has the in AND out for full flow or do you have to change the entire pump?
 Post subject: Re: OIL PUMP COVER ?
PostPosted: Mon Sep 21, 2009 6:06 pm
Gotta change the pump.
PostPosted: Mon Sep 21, 2009 7:35 pm
I looked to do the same thing but the ports on the cover and the pump did not line up correctly. However, the pump was extremely easy to replace. The hardest part was pulling the timing pulley..
Just for laughs.. I will tell you what i did. I installed the new pump and ran a hose from the in to the out to see if it was working. Started the buggy and let it run for a few minutes. All of sudden, I see oil shooting across the garage. The hose came off the pump and oil was shooting across the garage... What a mess..
PostPosted: Mon Sep 21, 2009 11:25 pm
let me explain what happened ........ ill try to keep it short
one of my buddys ordered a long block set up for dry sump (not drilled and tapped for full flow) and it only lasted 1 weekend of riding till it started that dreaded "knocking" sound due to no. 3 rod bearing failure. he had to have his crank turned .30 to clean it back up and the rod resized. we built it back ourselves and we were trying to figure out how to run it a little till broken and change oil and filter a couple of times just to make sure theres nothing going wrong this time without using all that oil in the dry sump setup every time til hes ready to go riding and "pull the bridle off" let it rip
PostPosted: Mon Sep 21, 2009 11:45 pm
if number 3 bearing aint oiling u got that problem to worry about,u better trace ur oil ports down and see why it aint oiling
PostPosted: Mon Sep 21, 2009 11:51 pm
anybody got a diagram of the flow for the oiling system?
PostPosted: Tue Sep 22, 2009 12:08 am
its in the cb performance book but mine is in the truck,look on there web site
PostPosted: Tue Sep 22, 2009 12:26 am
thanks
PostPosted: Tue Sep 22, 2009 11:06 am
u come out of the pump then to ur filter and/or cooler,what ever u want first,then back to ur block where its drilled and tapped,i think u can use a regular pump with that cover but u got to put a plug in the oil hole of the pump,i think,somebody will have to help me on this
PostPosted: Tue Sep 22, 2009 11:37 am
This is the CB system diagram:
This is a fullflow diagram:
I have started engines with CB dry sump pumps on my start stand w/o any issue by runniung a hose from right to left side of pump, just looping it.
Be sure to install a filter in that loop.
Fill the engine with 4 quarts or so of engine oil.
PostPosted: Mon Sep 28, 2009 8:59 pm
did u get it going yet???????????
PostPosted: Mon Sep 28, 2009 11:11 pm
yeah last thursday and then they left friday going to columbus ms with them damned dirt cars and didnt come back till midnight last night then worked today and got to go to montgomery tomorrow so maybe wednesday he will get to run it around a little and see how it is gonna do
PostPosted: Mon Sep 28, 2009 11:12 pm
also thanks for the all the info guys! :D
PostPosted: Mon Sep 28, 2009 11:17 pm
i know they was having a big late model race in columbus ms,,,how did they do???that big race there it takes a good racer to even finish that race,,wasnt saturday a 100 lap feature??
PostPosted: Mon Sep 28, 2009 11:24 pm
there was 54 in thier class only 24 got to make the main event and stacy finished 15th or 16th and trent finished 18th i think. they only ran 20 laps in the late model stock. the super lates ran the 100 laps on sunday because sat. there was water running out from under concrete wall around the track
