It is currently Mon May 04, 2026 3:53 pm
 Post subject: what do yall think?
PostPosted: Wed Sep 16, 2009 12:09 am
i have a buddy with a scat 2332 and a bernie bergman 2500 that both need rebuilding and he did not like the scat c35 cam in the 2332 nor the scat c95 cam in the 2500.
i told him to put a engle w110 with 1.25 rockers in the 2332 and a engle w120 with 1.1 rockers in the 2500, does anybody have any better suggestions?
 Post subject: Re: what do yall think?
PostPosted: Fri Sep 18, 2009 4:26 am
come on guys surely somebody has got some comments on this ??????
he is fixin to put one of these back together this weekend.
PostPosted: Fri Sep 18, 2009 7:39 am
The Engle 110 w/1.25 seems to work very well for most people. But, if I remember correctly the C35 has almost the same lift and duration as the 110. I think Wildwillie runs the Engle 120 and his runs like a raped ape.
PostPosted: Fri Sep 18, 2009 8:55 pm
Port the heads c35 1.25 scats are 1.3 .495 lift 246 dura 110 .509 L 247 D fk 6or7 &1.4 or fk41or42 2332or2500 good woods cam .For more top in w120 fk 7or 8 & 43 or go to bottem of the page & brag.
PostPosted: Fri Sep 18, 2009 9:16 pm
depends on what he wants out of them bottom end or top end power.if you stay with the 11o or something like a fk7 then that seems to give you alot more bottom than the 120 and higher fk cams imo.some guys like the 120 when they climb wide open but seem to load up and the power range to high to just lug around in the woods.if its got the 110 or fk7 then you can lug around and have alot more bottem end seems like about around 5000 to 5500 rpm on mine and it has all kinds of power and starts to fade out a little on top end but that could be a combination of cam and carb does this sound about right for what everybody seems to run.i dont complain about what i lose on the top its not enough to bother me i love the fact i can get in and out of the gas and not have to be wound plum tight to keep my power turning the wheels,and can 2nd and 3rd gear lug around all day and doesnt load up and i dont think i use all that much fuel.chad :mrgreen:
PostPosted: Sat Sep 19, 2009 2:17 am
PostPosted: Sat Sep 19, 2009 8:44 am
ridenrace6 wrote:
yea i was wondering about this myself.chad :mrgreen:
PostPosted: Sat Sep 19, 2009 9:26 am
gasman wrote:
And talk about how big a cam you have :roll:
PostPosted: Sat Sep 19, 2009 9:47 pm
i'm running 2276 and fk-8 and love it!!!!
PostPosted: Sat Sep 19, 2009 9:50 pm
i'm running 2276 and fk-8 and love it!!!! i thought rpm range was a lil high but its good!! :D :D
PostPosted: Sat Sep 19, 2009 10:39 pm
You mean Its All Good! :twisted:
Awesome 2387 Beeline Cobra
PostPosted: Sat Apr 28, 2012 9:10 am
hate to revive old threads... but... what compression are you guys running with your W110?
I have a 2165 with about a .050 deck will end up with about 9.5.1... But I see that they recomend no higher than 8.5.1
just want to be sure I am understanding you guys right...
PostPosted: Sat Apr 28, 2012 9:59 am
fk-43 with 1.4 rockers make sure your heads are breathing 9-1/2-1 comp. works real good with a 2500 .
PostPosted: Sat Apr 28, 2012 7:04 pm
11 to 1 on race gas and ported heads
PostPosted: Mon Apr 30, 2012 5:58 pm
5.5 to 1 CR with single port heads on a 1300 , drilled valves, and a reground cam. (Bench grinder works good). Runnin veggie oil.
