It is currently Mon May 04, 2026 12:27 pm
 Post subject: iac ??
PostPosted: Sun Sep 13, 2009 9:07 pm
what is every body doing with the aic running it or blocking it off and why and some pics please
 Post subject: Re: aic ??
PostPosted: Sun Sep 13, 2009 9:25 pm
I run mine, its wired complete as stock. Thats the way the factory did so thats why Im using mine. Somtimes Id like to block it off cause when Im going slow the comp trys to go faster.
PostPosted: Sun Sep 13, 2009 9:26 pm
What is an AIC?
PostPosted: Sun Sep 13, 2009 9:28 pm
Firebug wrote:
What is an AIC?
I assume its IAC "idle air control motor"
PostPosted: Sun Sep 13, 2009 9:39 pm
Are you running the tube from the iac to your intake between the maf and the throttle body? I just got mine running to day and the only way I could get it to idle was to block off the tube on the iac.
PostPosted: Mon Sep 14, 2009 8:28 am
You can adjust that, you know?
Loosen it, then turn it to adjust the idle, mine is set at 450 rpm.
PostPosted: Mon Sep 14, 2009 8:40 am
I noticed in your build that you welded up the heater lines.
I've installed a heater in mine for comfort, with a shutoff on the heater line, but when I closed that valve to block the hot water from reaching the heater core in summer, it instantly begain to overheat.
I wonder if that might be your problem.
 Post subject: Re: iac ??
PostPosted: Mon Sep 14, 2009 6:17 pm
Yes Its hooked to the intake between the maf and throttle body.
