It is currently Sun May 03, 2026 11:16 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: My Subi swap
PostPosted: Fri Aug 14, 2009 8:37 am
Very nice Install! Looking real good.
PostPosted: Thu Sep 03, 2009 8:51 am
Had to modify the throttle body to clear the frame. Thanks to my buddy rail1914 (Randy) and Bill for the help. Here are some pics
I picked up some 2.75 aluminum
PostPosted: Thu Sep 03, 2009 9:47 am
Curious why you did not use the whole 180 degree pipe and use a silicon coupling to attach the MAP sensor.
PostPosted: Thu Sep 03, 2009 8:20 pm
I am not sure if I'm going to run the filter straight back or to the side. This way I have more options.
PostPosted: Sun Sep 13, 2009 10:13 pm
Finally got the radiator back, here are some pics.
PostPosted: Mon Sep 14, 2009 6:19 pm
Looks good, I need a pipe like that too.
PostPosted: Mon Sep 14, 2009 9:01 pm
Scott, how is the radiator mounted, is it rubber isolated ?? If not you mignt want to think about it.
