It is currently Tue May 05, 2026 12:45 am
 Post subject: GOTTA A MISS
PostPosted: Wed Sep 09, 2009 9:24 pm
o.k i got a miss i've check compression all 4 around 160 lbs i've changed wires,plugs,cap,rotor,sprayed for vacuum leaks seems to be the back 2 cylinders any suggestions. :cry:
 Post subject: Re: GOTTA A MISS
PostPosted: Wed Sep 09, 2009 9:43 pm
Check rocker movement on the back two cyl. Maybe a lobe on the cam is flat since they share cam lobes.
PostPosted: Wed Sep 09, 2009 9:56 pm
they got good movement forgot to say checked that to :?
PostPosted: Wed Sep 09, 2009 11:52 pm
what kind of carb set up u have?
PostPosted: Thu Sep 10, 2009 12:52 pm
Holley 4 barrel.
PostPosted: Thu Sep 10, 2009 3:47 pm
holley 500 2 barrel 4412
PostPosted: Thu Sep 10, 2009 5:09 pm
what kind of ignition are you running? when i was running the 09 distributor, i was kind of having the same problem, it turned out the ignition wasnt hot enough to burn all of the fuel. you might want to try a little hotter coil, see if that would help.
dave
PostPosted: Thu Sep 10, 2009 8:57 pm
O.K. i found it say i'm crazy but ..... finally had time to set down and do something so i had valve cover off driver side all the rockers was moving equally that why i said no flat lobes.none loose so i reset them and move to pass side . when i pulled the cover off i noticed no.1 exhaust rocker was backed off(IN A HURRY MUST HAVE FORGOT TO TIGHTEN DOWN) :oops: :oops: :oops: so i reset it and started it up and it sounded great again. but now gotta set carb again. i'm running a 2276 , cb 044 40x35 fk-8 10.5 to 1 compression and a 500 holley it runs great!!! im use to a 1641 soooo. lol . so anyway i would have never imagined a backed off rocker could cause so much headache. god im glad i could nt go back to a 1641. :mrgreen: :mrgreen: :mrgreen: THANK GUYS
PostPosted: Fri Sep 11, 2009 4:29 pm
Sorry I thought you said a 4 Barrel when we were looking at it over the weekend. :oops:
PostPosted: Fri Sep 11, 2009 10:54 pm
what kind of manifold are you running ? Do they still make the Johnnys 4 play manifolds ?
PostPosted: Fri Sep 11, 2009 11:01 pm
they still make johnny 4 play but i think he has a 2 barrel
PostPosted: Fri Sep 11, 2009 11:44 pm
homemade made it myself. :mrgreen: :mrgreen:
PostPosted: Sat Sep 12, 2009 8:03 am
I had a Johnnys 4-play intake on my old buggy with a 650 Holley and it did not do anygood luck for me, I even tried Edlebrocks and still no luck, It was loading up everytime I go up a hill whether u get into it or just riding around. It works great on level ground and takes off like a scaled dog. I have been through all of the float adjustments and jettings to make it work, no good, I rather stick with my dual webers for now :roll: That is good to hear that you got her running good though.
PostPosted: Sat Sep 12, 2009 10:45 am
A guy I ride with has several of those 2 brrl carbs sitting around off there dirt car and we were wanting to try one since they are just sitting there .We thought about just running the 2 to 4 brrl adapter on a 4-play manifold But I would like to see a picture of the one you made .
