It is currently Mon May 04, 2026 9:51 pm
 Post subject: adjusting a 44 weber
PostPosted: Wed Sep 02, 2009 7:08 pm
what screw does what. the carb does good at 1250 rpm and up but be low that it die out you can hold your hands over the stacks a little it will run at 1000 rpm. so what is wrong. what need tobe adjusting im about to set it afire
here hold my beer and watch this shit!!!!!
 Post subject: Re: adjusting a 44 weber
PostPosted: Wed Sep 02, 2009 8:02 pm
sounds like a intake manifold leak or a clogged idle circuit
PostPosted: Wed Sep 02, 2009 11:41 pm
i have replaced all the gaskets rebuit the carb five time sok it two time. u can blow air trow everything good. i just dont know
PostPosted: Thu Sep 03, 2009 12:09 pm
assuming that you are running a single carb, run the air mixture screw ( the two that have springs at the base of the carb) till it starts to die, then back out 1/4 turn. Then turn the idle speed screw down. If that doesn't take care of it, and you don't have any air leaks, its time to change up your idle jets.
PostPosted: Thu Sep 03, 2009 8:35 pm
just did changed the jets it fixed now went from 50 to 65 it worked :D :D :D
PostPosted: Fri Sep 04, 2009 8:01 am
Good!!!! :mrgreen:
PostPosted: Fri Sep 04, 2009 10:36 am
if u ride this weekend and u find that it waste alot more gas than normal,u might have to go down one size on ur idle jets,a smaller motor needs bigger idle jets,most of the time,webers are hard to great right
