It is currently Mon May 04, 2026 3:00 am
 Post subject: smoked my clutch disc
PostPosted: Tue Sep 01, 2009 8:07 am
this is whats left of my cushlock clutch disc. the stage 2 pressure plate has some hairline fractures so im gonna replace it to. suprisingly the flywheel is ok. is anyone using a 6 puck kennedy clutch. this was recomended by mckenzies and outfront when using a subi 2.5 dohc no turbo. any input is appreciated.
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Sep 01, 2009 10:20 am
thats what ive been running for around a year is a 6-puck,works so much better than a 4-puck
PostPosted: Tue Sep 01, 2009 10:36 am
I have been using a 6 puck,,on the 2.2 I had a stage 2 pp but now with the 3.3 I am using a stage 4 also with 6 puck. I like it. Some folks talk of chatter but mine are smooth as stock.
There are 2 stage 3 pp on ebay,,,I think stage 3 might be the ticket
PostPosted: Tue Sep 01, 2009 11:32 am
Stage 4 and a 6 puck here, too. No chattering at all, but I have heard others say theirs did.
My disc came off of Rhonda's buggy, she ran it for a couple rides and didnt like it because it chattered. I think it had a stage 2 pressure plate on it then. My motor was off my buggy at the time, so we just traded for my kush lok. Other than gearing and p.plate, our buggies are very similiar, but it chattered in hers and not at all in mine. Dont really make sense.
Maybe they work better with a heavier p.plate??
PostPosted: Tue Sep 01, 2009 3:33 pm
Your's kinda looks like this one PB.
Turbo 2332 bug, 6,000 RPM launch, on asphalt, in third gear.
No it wasn't me........
8)
PostPosted: Tue Sep 01, 2009 4:11 pm
Yeah! that would do it! :shock:
8)
PostPosted: Tue Sep 01, 2009 4:20 pm
[quote="turboblue"]Your's kinda looks like this one PB.
ouch!
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Sep 01, 2009 4:31 pm
gonna hop up to the kennedy stage 3 pp with the 6 puck clutch disc http://www.appletreeauto.com/6-puck-clu ... -1277.html
fb thanks for the pm with the ebay link on the pp. trying to put this together for the weekend so ebay just isnt an option.
- Sigmund Freud
- Antonio Meloni
PostPosted: Sun Sep 06, 2009 7:54 pm
why is the disc burned on the out side only
PostPosted: Sun Sep 06, 2009 8:39 pm
looks like its fried on both sides to me
PostPosted: Mon Sep 07, 2009 9:55 am
your right i mean on the outher edge only :)
PostPosted: Mon Sep 07, 2009 5:03 pm
on the flywheel side, the clutch disc stuck to the flywheel and came out in pieces. on the pressure plate side it was dust.
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Sep 12, 2009 8:16 am
The chattering that everybody is talking about is caused by (I think) if you are running a slave cylinder (hydraulic) and if it is set too tight, it will cause it to chatter, mine used to do that until I got the cylinder adjusted and it went away, and all I am running is a 4-puck and a stage 1 pp, never slipped once on me and am running a 2276cc, and still running the same clutch and pp for almost 3 years now :mrgreen: My first buggy had a kushlok clutch and stock pp and it chatters when I got it and found that it was set too tight and then adjusted it a little loose and it went away.
