It is currently Mon May 04, 2026 8:55 pm
 Post subject: Ball joint spindle stub
PostPosted: Sat Aug 15, 2009 1:00 am
I’m wondering if anyone sells just the spindle stub for a ball joint. I found some combo stubs but not sure on the ball joint stub. I don’t want to cut up a good ball joint spindle if I can get the stub cheap.
Thanks, Brad
PostPosted: Sat Aug 15, 2009 8:56 am
I have stock type link pin spindle stubs and I have the big 'combo' spindle stubs as far as I know they don't make a ball joint spindle. You could always make your own ball joint stubs.
PostPosted: Sat Aug 15, 2009 4:05 pm
Look at Empi part # 16-9914 and see if it can be something you can modify and use .
http://www.empius.com/2009_catalog/images/190.jpg
PostPosted: Sat Aug 15, 2009 10:29 pm
tim at southern buggys ,,15.00 a peice
PostPosted: Sun Aug 16, 2009 7:46 am
Drews has them $40/pair.
PostPosted: Sun Aug 16, 2009 8:54 am
What we use on a K/P. Cut the K/P off use the B/J.
Can not beat the price.
PostPosted: Sun Aug 16, 2009 10:29 pm
thanks guys thats what I need.
afterburnt can I use you’re expertise and shop to do my spindle repair? Once I get the new spindle.
PostPosted: Mon Aug 17, 2009 5:29 pm
ya, your more than welcome, just give me a call, and let me know when you want to come over. I'll pm you my phone number.
dave
PostPosted: Wed Sep 09, 2009 7:34 pm
hey brad, how did that spindle work out? i was kind of curious if you put it on yet, and if that weld got in the way of the seal.
dave
PostPosted: Thu Sep 10, 2009 1:54 pm
The front end is complete. The weld was just touching in one spot so I ground it down a little. I think the upper control arm is still bent because I have major camber that can’t be adjusted. I don’t have time to fix it before this weekend so I am going to run it.
Thanks again for the help Dave
You going to make it this weekend? I should be there sometime Saturday morning.
Users browsing this forum: Majestic-12 [Bot] and 0 guests
