It is currently Tue May 05, 2026 2:16 am
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: v6 buggy biuld
PostPosted: Sat Aug 15, 2009 1:31 pm
Finally got it going ,still have some things to do to it but at least i'm in the woods..
PostPosted: Sat Aug 15, 2009 3:36 pm
man that thing is killer !!!!
PostPosted: Fri Dec 25, 2009 11:16 pm
Got the chain drive done gonna test it at D&K newyears weekend, I hope anyway.
PostPosted: Sat Dec 26, 2009 10:01 am
see you there, looks good
PostPosted: Sat Dec 26, 2009 2:37 pm
wow I want to see some vids of this thing taking on some hills!
PostPosted: Fri Jan 01, 2010 12:17 pm
Looks great, hope it's hooking up better now, wanting to build a similer setup out of my old 902 shortback, so get the bugs worked out for me :shock:
PostPosted: Thu Jan 21, 2010 9:12 pm
well ive been loving this machine ever since you started on it and its killing me to know how your chains did for you.so give us an update please.chad :mrgreen:
PostPosted: Fri Jan 22, 2010 7:19 pm
did anybody else go,how did this set up work.come on somebody tell. :mrgreen:
PostPosted: Mon Jan 25, 2010 6:56 pm
Sorry gasman not been online for a few days.
Well the day started great the bolted tires rocked!! but on the second hill i climbed about halfway up the stub axle on the yota diff came out causing the chain to come off and damaged two sprockets and the chain.
I've not even got it off the trailer yet ,kinda tired of working on it and frustrated with it ,thinking about trashing the chains and going with a th350 for the lower gear . I just hate to strech the wheel base with the th350 its about 3.5 " longer then the pg and with losing the chains it will put the wheel base from 101 now to about 108-110.
I beleive the chain drive may work but i'd need to make something to take the pressure off the diff,still thinking on it..
Later..
PostPosted: Mon Jan 25, 2010 7:11 pm
Me and you should buy stock in drawing boards as much as we go back to them...I got confidence in you though that you will get it figured out. good luck :wink:
PostPosted: Mon Jan 25, 2010 7:36 pm
Later..
i hate to hear that,but you will get it figured out.this is a wicked nice ride and cant wait to see it in action.maybe next time.chad :mrgreen:
PostPosted: Mon Jan 25, 2010 8:32 pm
Just tossing an idea out there for ya WB. Not sure how but make a shaft coming off of the diff sprocket to another bearing so it takes the twist out of it under load. Sorry havn't had autocad in about 10 years, but here's my idea, kinda, :roll:
PostPosted: Fri Mar 05, 2010 12:14 am
wbsouth wrote:
The v6 is only 200 hp but the torque is what counts its 265.
And yes I thought about a v8 but the weight versus power and torque and money didnt seem worth it , in stock form that is.
If or when i do an upgrade it will be a turbo suby or an all aluminum v8 , maybe when the kids get grown lol..
a procharger is an easy and reliable way to make real good power on just about anything...
PostPosted: Fri Mar 05, 2010 5:31 am
Word is that this buggy will be at Stony March 6 hill climb,,,let's go see it. :wink:
PostPosted: Fri Mar 05, 2010 11:35 am
That thing is BAD A$$!!! I'd trade my wife for one of those...... :shock:
PostPosted: Sat Mar 06, 2010 12:07 am
what size and thickness box tube did you use on the rear trailing arms? I am thinking of making my new buggy have chains inside the arms and yours seem to be a good design on what im thinking of doing...
hopefully you get it lined out
PostPosted: Sat Mar 06, 2010 3:03 am
but doesn't he have bolted tires????
PostPosted: Fri Mar 12, 2010 7:46 pm
I used 1.25 tubing 1/8 thick for the arms.
I borrowed some boggers from a friend for the hillclimb,got the bolts back on now and we're gonna tear it up tommorow.
