It is currently Tue May 05, 2026 1:58 am
PostPosted: Wed Jul 29, 2009 9:16 am
Any one got a good trick for putting the springs back in the front torsion tubes? Linkpin
PostPosted: Wed Jul 29, 2009 9:32 am
Push them together real tight at the end, and put a zip tie/ hose clamp about an inch or less from the end, as tight as you can. When you push it through the square in the middle, it will stop the zip tie and let the springs stay together and push on through.
That's what I did, worked great for me.
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Jul 29, 2009 1:17 pm
Thanks, your still ok with me. :wink:
PostPosted: Wed Jul 29, 2009 1:24 pm
I also grind just a little on mine to give them a little angle on the sides to help guide them through the center.
PostPosted: Sun Aug 02, 2009 2:28 pm
Ok for something so simple that was a major pain in my !!!!! But it's done, thatnks for the advice guys.
PostPosted: Sun Aug 02, 2009 8:54 pm
I know you already have yours in now but I put the spring leaves into the arm and snug the jam nut down that way I can use the arm as a handle and slide them in to the beam ( i also grind the ends down slightly like Fire bug said )
