It is currently Mon May 04, 2026 10:00 am
PostPosted: Mon Jul 20, 2009 8:21 pm
What is ever one doing for tie rods? I have bent, broke welded and rewelded the stockers on my rail. Now its time for new ones. Will the stock vw ends be strong anuff? I am thinkin of usein some DOM for the tie rods its self.
Pics would be very helpfull..Also I am usein a stock vw sterring box.
PostPosted: Mon Jul 20, 2009 8:37 pm
I use this and tap it for rod ends,,,little heavy but I never bent one yet
http://www.metalsdepot.com/Cart3/viewCa ... c=&aident=
PostPosted: Mon Jul 20, 2009 8:51 pm
The strongest set up are 3/4" chromolly heims, high angle spacers and steel swegded tubes.
Tubes http://www.speedwaymotors.com/Swedged-S ... ,2091.html
Heims http://www.speedwaymotors.com/rod-ends- ... t_answer=1
PostPosted: Tue Jul 21, 2009 12:28 am
I used the off road tie rods from Latest Rage. I believe they cost around 37 each but you will need to cut and retap one end to make them fit and ream out your spindles to fit the ford tie rod ends.
PostPosted: Tue Jul 21, 2009 12:10 pm
My woods buggy had the thinnest alum. tie rods I have ever seen, and I ran those for years without ever bending one. The only time I bent one was when I broke a link pin and wraped it around the coil-over :roll: I then stuck it in the reciver on my truck and bent it back, and was good till I made a wider beam! IMO the hollow tie rods are way stronger than the solid ones. Also if you can run international ends, they seen to be stronger than the ford ends. Or heim joints are the way to go if you have the $. I also run alum heims.
PostPosted: Tue Jul 21, 2009 11:00 pm
Aluminum heims wont make it too far in the woods. For about $130 you can go 3/4 X 3/4 chromolly heims and steel tubes. I've been running them for 5 years now, $26 a year is pritty inexpencive.
