It is currently Mon May 04, 2026 10:45 am
 Post subject: 091 6 rib
PostPosted: Wed Jul 15, 2009 9:51 pm
I talked with a buggy builder today and he said to be very careful with the new engine (Ecotec 2.4 L) because I will tear my transmission up because of the amount of torque the engine has. I just had my transmission torn down and rebuilt and everything looked good on the inside. I called the guy who rebuilt my tranny and he said not to worry about it because he has been running a 6 cylinder and has not had any problems caused by the power. On the other hand the buggy builder said I should at least put in a ring and pinion made by Richmond (At least that is what I thought he said) and distributed by Weddle. I posted in another topic asking for the price of the ring and pinion but I would like some thoughts on this before I go and have it torn down again.
Thanks,
Bryan
 Post subject: Re: 091 6 rib
PostPosted: Wed Jul 15, 2009 10:20 pm
Be sure to run a superdiff,,or 4 spider,,,whatever you call it...chromole pinion nut,,or whatever you call it,,, :oops:
PostPosted: Wed Jul 15, 2009 11:44 pm
do what firebug said and then take it easy because that tranny will hold up for a while but,, its not if its gonna break its when,because it will sooner or later,then if u want a strong tranny get ready to spend some cash
PostPosted: Thu Jul 16, 2009 6:33 am
Anything can and will break. 10-4
PostPosted: Thu Jul 16, 2009 10:07 am
It is my understanding that a 6 rib with a super diff will handel up 300 HP before you have issues. Keep in mind that even the best built trans will break if your off the ground andkland with throttle on. Be nice to it and it will be nice to you.
PostPosted: Thu Jul 16, 2009 3:17 pm
This all depends on two things..........what tires you use and how heavy your buggy is.
PostPosted: Thu Jul 16, 2009 11:55 pm
Mickey Thompson Baja Claw radial 33x12.50x15 and I would estimate the buggy to come in at 1600 to 1700 lbs.
PostPosted: Wed Jul 22, 2009 10:01 am
You will tear up a stock 6 rib with that combo. You will need to invest in some aftermarket parts to put in it to make it last. :|
PostPosted: Wed Jul 22, 2009 10:55 am
What about a stock 84 Vanagon side shift with a super diff on my Buggy with 33 X 12.5 x15 cut Boggers?
PostPosted: Mon Jul 27, 2009 6:10 pm
Weddle ring and pinion and a weddle super diff or just the super diff?
PostPosted: Wed Jul 29, 2009 9:50 am
I wouldn't worry about the ring and pinion so much. A stock 4:56 is the strongest stock r&p you can get. Depending on how you drive, it could last forever. I have relentlessly beat the crap out of my stock 4:56 for 3 years of trail riding and then 3 hard years of racing pushing close to 200 HP with no issues. I have blown first gear before. Run a cromo pinion nut and a super diff, and use you head, and it should hold up.
PostPosted: Thu Jul 30, 2009 5:23 pm
Where is the best place to order the super diff?
PostPosted: Thu Jul 30, 2009 5:59 pm
Weddles # is 805-562-8600
Stock Diff $14.50
Used Spiders $24.50 Ea
New Spiders $44.23 Ea
Cast Super Diff $169
Chromolly Super Diff $470
4.57 R&P Used Good $395
New Chromolly $856.80
Prices they quoted me a month ago.
And don't forget about the Diff cover, Thrust Washers, Side Thrust Washers, and Bearings. It adds up. Oh and your tranny guy probibly wants paid too. Welcome to the higher HP club, lol.
PostPosted: Thu Jul 30, 2009 11:42 pm
i give 350 for a complete used german diff,they are the best
PostPosted: Fri Jul 31, 2009 8:27 am
For just playin around in the woods, a cheapy superdiff would be fine. Unless you are going to be throwing unusual amounts of punishment at it, get the cheap one.
