It is currently Sun May 03, 2026 3:29 pm
 Post subject: fuel system
PostPosted: Mon Jun 15, 2009 3:27 pm
What is everyone using for the fuel system. I priced all an fittings to do a pre filter, pump, post filter, and then a regulator. And it is going to be a couple hundred bucks. My question is what did everyone use for fuel filters, fuel line, and what type fittings. I have already got my fuel pump and regulator. Now I need to figure out what else to use.
Thanks for any help.
 Post subject: Re: fuel system
PostPosted: Mon Jun 15, 2009 5:11 pm
I used high pressure rubber line. The fuel pump came from a v-12 jaguar and the filter came oem on the subaru, I also added a prefilter to keep dirt out of the pump. Total cost for fuel system was under 100 bucks.
PostPosted: Mon Jun 15, 2009 9:30 pm
What did you use for a prefilter? And what type fittings did you use? The ecotec runs at 58 psi at idle. I just don't want to waist money and it leak.
PostPosted: Mon Jun 15, 2009 9:46 pm
I used brass fittings and went to local parts house and got a filter with 1/2 inlets for carbs. Used fuel injection rubber hose and clamps. The stock subaru uses rubber from line at frame to filter and then to the fuel rail. Ijust used the suby stuff as much as possible. The jag pump is capable of 80 psi in stock form. I have no leaks and beat on it pretty hard. I will get you some pics tomarrow.
PostPosted: Mon Jun 15, 2009 10:36 pm
Here is what I have spent all day figuring out. And it isn't very cheap. http://www.summitracing.com/checkout/cart.aspx
PostPosted: Tue Jun 16, 2009 7:56 pm
Nothing here?
PostPosted: Thu Jun 18, 2009 9:19 pm
Well I guess it will just show on mine. It was 323.00 for the fittings and hose.
PostPosted: Fri Jun 19, 2009 7:52 am
My system is dual fuel pumps and filters with Billet fuel rails all plumbed in braided Stainless steel line with AN fittings.
PostPosted: Sat Jun 20, 2009 2:00 pm
Lots of high flow parts for a low flow motor! :D
PostPosted: Tue Jun 30, 2009 8:43 am
Only untill the Turbo spools up! :mrgreen:
PostPosted: Tue Jun 30, 2009 7:21 pm
:D
