It is currently Mon May 04, 2026 7:12 am
 Post subject: my subi swap
PostPosted: Wed Jun 17, 2009 7:47 pm
i just started my subi build thanks to big scottImageImageImageImageImageImageImageImageImageImageImage
 Post subject: Re: my subi swap
PostPosted: Wed Jun 17, 2009 8:48 pm
Sweet suicide doors! Keep the pic coming!
PostPosted: Wed Jun 17, 2009 8:50 pm
I am about to start the same thing. Good Luck and keep the posts coming.
PostPosted: Wed Jun 17, 2009 9:21 pm
those doors are wild.cool baja,i noticed that you still had the metal fender on it cool.istill got them on mine in the back,i took front wide fenders cut them just above the light buckets turned them around and put on the back so they would be alot wider.just a thought since you had steel on the front.chad :mrgreen:
PostPosted: Wed Jun 17, 2009 9:47 pm
Looking good Randy. I still think you need to keep the ac on the subi engine and hook it up! :D
PostPosted: Wed Jun 17, 2009 10:07 pm
not we could still do yours
PostPosted: Sun Jul 05, 2009 9:53 am
on a baja every thing sits up higher so i just moved the factry shifter to the top of the trans and flip everything the shifter rod just runs to the side now shifts smooth now iv got a big hole in the center to fill and i finely got my seats in all so with every thing fliped the shift pattern is right just need to make everything look good now ImageImageImageImageImageImage
PostPosted: Mon Jul 20, 2009 10:07 pm
still working all most finshed the rad braceing here are some new picsImage ImageImageImageImageImageImageImageImageImageImage
PostPosted: Sun Sep 06, 2009 7:49 pm
havent gave up yet ImageImageImageImageImageImageImageImageImageImage
PostPosted: Sun Sep 06, 2009 11:09 pm
Looks like you got it goin on,,,love it,,,keep them pics coming and let us know how you like the suby power.
PostPosted: Mon Sep 14, 2009 8:52 am
[quote="rail1914"]on a baja every thing sits up higher so i just moved the factry shifter to the top of the trans and flip everything the shifter rod just runs to the side now shifts smooth now iv got a big hole in the center to fill and i finely got my seats in all so with every thing fliped the shift pattern is right just need to make everything look good now
By flipping the shift arm, didn't you just reverse your shift pattern?
4th will now be 1st?
Not that it matters, it will make it harder to steal.
PostPosted: Mon Sep 14, 2009 5:40 pm
[quote="Maddog"][quote="rail1914"]on a baja every thing sits up higher so i just moved the factry shifter to the top of the trans and flip everything the shifter rod just runs to the side now shifts smooth now iv got a big hole in the center to fill and i finely got my seats in all so with every thing fliped the shift pattern is right just need to make everything look good now
Not that it matters, it will make it harder to steal.[/quote some what 1st is where 2nd was you pull for 1st now and push for 2nd
PostPosted: Mon Sep 21, 2009 10:25 pm
allmost done with rad support the top plate is 1/4 in alum it bolts the front bar to the back bar the front bar is welded to the bumper and beam and the back bar is welded to the frame and inside cage bolting the two together acts like a race brace in the middle ImageImageImageImageImageImageImageImageImage
PostPosted: Tue Oct 20, 2009 9:16 pm
up date still working on roll cage ImageImageImageImageImageImageImage
PostPosted: Wed Dec 02, 2009 10:59 pm
starting to look like a buggy :D :D ImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImage
PostPosted: Wed Dec 02, 2009 11:02 pm
Your doing great,,keep up the good work,,,your gonna be proud of it :wink:
PostPosted: Wed Dec 02, 2009 11:15 pm
Looking good Randy! Now get it done so we can go ride!!!!!!!!!!!!
PostPosted: Wed Dec 02, 2009 11:37 pm
thanks firebug and soon scott
PostPosted: Fri Dec 04, 2009 8:54 pm
that looks great
PostPosted: Sat Dec 05, 2009 12:29 am
PUNCH-BUGGY :shock:
PostPosted: Wed Jan 27, 2010 10:32 pm
had starter problems i have a vangon trans with a 3 rib bellhousing and a vangon starter so i made an adaptor for the starter from an old starter it works great and on the + side i can run any starter nowImageImageImageImageImageImageImage
