It is currently Sun May 03, 2026 10:42 pm
 Post subject: Radiator Ideas
PostPosted: Sat Jun 13, 2009 11:25 pm
I am going to be starting my conversion to a Subi 2.2 in a few weeks and I am looking some ideas on radiators.
I like the Cherokee Radiator that measures 31 X 11. Will that provide enough cooling? Does anyone sell small fans that will fit or a small shroud?
What are the recommendations?
 Post subject: Re: Radiator Ideas
PostPosted: Sun Jun 14, 2009 12:18 am
I use two empi fans on my 1.9L. Works fine. The one thing that I don't like is that they are loud, very loud. Sounds like a plane getting ready to take off at times. I wish I had went with stock fans of some sort. Much quieter than mine.
I used the jeep radiator also.
Not a good picture of my fans but if you want I can snap a better one if you need.
Bryan
PostPosted: Sun Jun 14, 2009 8:23 am
This what I use on my 2.2 Suby, It works great . I small compact and easy to mount and protect. Cools fine even on a 95 degree day.
http://cgi.ebay.com/ebaymotors/CXRacing ... ccessories
You can also check this thread!
viewtopic.php?f=17&t=5516
PostPosted: Sun Jun 14, 2009 2:59 pm
my buddy was running a 4.6 bush grand national engine and now he has switched to a 350 chevy and he is running a howe 2 core aluminum radiator and it only measures like 3 in thick tanks by 19"x22" and i think they run around 175.00 dollars .chad :mrgreen:
PostPosted: Sun Jun 14, 2009 3:25 pm
I use a Fiero radiator,,I like it because the inlet is on the side it needs to be on,,and it is not too big , and it cools well,,,this ebay ad has dimensions.
http://cgi.ebay.com/ebaymotors/PONTIAC- ... ccessories
you are better off getting one from the salvage yard and get the fans and shroud with it,,,
PostPosted: Sun Jun 14, 2009 4:14 pm
firebug you are an ebay master aint you,you must have some ebay stock lol.you do get some good deals on there and thats a good thing.lol. :mrgreen: chad
PostPosted: Sun Jun 14, 2009 8:03 pm
Thanks for all of the great ideas.
How much air flow does the radiator required (with out the fan on) Is it OK to tuck the radiator behind the seats? I have seen fans on the front of the radiator and the back of the radiator, does it matter? Are the back fans a "Pull" fan and the front fans a push fan?
Thanks again for all of your input
PostPosted: Sun Jun 14, 2009 9:39 pm
Do you really want 200 + degrees right behind you? Picture a 90 degree day going slow thru the woods. For best performance you want the fan(s) to pull thru the radiatoe and away fro m the engine. Ebay and Summit racing are good sources for radiators, Hoses etc
PostPosted: Sun Jun 14, 2009 10:28 pm
I was going to run the stock radiator and fans. Has anyone done that?
PostPosted: Thu Jun 18, 2009 9:04 am
I run a stock 2001 Dodge Intrepid 3.2L radiator with dual fans on my 2.8L Chevy motor. Hasn't gone over 190 yet. Checked with the engine mostly standing still and alot of it in the garage. Shouldnt do too bad on the trail with air moving.
PostPosted: Thu Jun 18, 2009 9:06 am
Just wanted to say thanks for all of the ideas and comments.
