It is currently Mon May 04, 2026 10:00 am
 Post subject: anti-theft bypass
PostPosted: Mon Jun 08, 2009 12:07 pm
Does anyone know how to trick or bypass gm anti theft. This winter i want to install 02 ecotec in my buggy. I am on a budget and plan on using original computer and harness and eliminating what i don't need. I have studied the schematics and the only real concern is the theft deterent. Under normal circunstances the ignition lock cylinder sends a voltage signal to the body control module which i of course won't have and in turn the bcm sends a message over the class 2 serial data line to the ecm to allow the engine to run. Is this a voltage or ground signal or some kind of binary code and does anyone know how to get around it? Thank you very much for any info.
 Post subject: Re: anti-theft bypass
PostPosted: Mon Jun 08, 2009 8:07 pm
call sinister performance for $60 they will redo the ecu chip and take all the bs out of it like the transmission controls and the pass key bs http://www.gmtuners.com/ there in fort wayne indiana
PostPosted: Sun Jun 14, 2009 10:56 pm
Thanks for the info i,ll give them a call .
PostPosted: Fri Jul 31, 2009 1:00 pm
I know this is kinda old, but I had to do this on my engine. Depending on which generation pass-key it is, you can build a little circuit that will send the serial signal to the computer to make it think the anti-theft device is there. It cost me like 10 bucks in radio shack parts and it works great.
I'm going to set it up to where I have a tiny hidden toggle switch to disable the circuit and it'll be my theft deterrent, lol.
Just search for pass-key bypass, or something along those lines.
Get me that hammer, pronto!
PostPosted: Sun Aug 02, 2009 9:51 pm
mine is an 02 ecotec from a grand am. You found info on an internet search on how to do this?
PostPosted: Mon Aug 03, 2009 12:18 pm
Yeah, I found it on the net.
That's quite a bit newer than mine, but it's still worth a search.
