It is currently Tue May 05, 2026 1:12 am
 Post subject: Top arm shock mount
PostPosted: Wed May 06, 2009 10:07 pm
I have never seen this before but out West they are doing trailing arms with the shock mount on top. I guess its been done for years on race cars but I never noticed. With the forward slanted shock towers and a high top rail they are getting 20" plus of front travel. I found it interesting so I thought I would share. The topic is posted on http://www.glamisdunes.com
 Post subject: Re: Top arm shock mount
PostPosted: Thu May 14, 2009 12:39 pm
Thats what I'm doin with the beam for my woodsbuggy. I should have the beam done tonight. :mrgreen:
PostPosted: Thu Jun 04, 2009 10:24 pm
i bent my stock beam on mem wknd. a tree at about 20 mph. Anyway im on a budget and and i just have stock arms for now but i was considering making my own shock mounts while im in threre. Also going to mount my steering rack. I was looking at my stock arms after reading this and it looks like the bottom and top could be swapped. Any reason they cant be? If not i may just mount my shocks on top that way.
PostPosted: Fri Jun 05, 2009 8:09 am
no, you cant just switch them. the bottom arm sticks out further than the top.
as you can see, I had to build the beam a little shorter on top.
PostPosted: Fri Jun 05, 2009 10:56 am
Hmmmmmmmmmmmm......... Maybe im going to attempt this. :?
PostPosted: Fri Jun 05, 2009 11:00 am
what about 2 bottoms :?: prolly not hunh? need the shorter distance on the top :?:
PostPosted: Fri Jun 05, 2009 12:44 pm
Yes you need the shorter on top to allow the suspension to work. Otherwise at about half compression your tire is going to be leaning out with about +5 degrees of camber. Not even to mention your bumpsteer :shock:
"Lets go get stupid"
PostPosted: Fri Jun 05, 2009 12:51 pm
and broken king pins
PostPosted: Fri Jun 05, 2009 5:11 pm
Thanks. I'll just put it back together stock untill i can afford what i want. 6 in wider and coilovers.
