It is currently Mon May 04, 2026 9:58 pm
 Post subject: oil pressure
PostPosted: Sat May 30, 2009 9:51 pm
what does yalls oil pressure run ? I have never run a gauge just an idiot light but I put one on the new buggy
after riding an hour or so and the engine is good and hot it will read about 18- 20lb idling around a trail and about 45lbs in the gas .
 Post subject: Re: oil pressure
PostPosted: Sat May 30, 2009 9:59 pm
That is about the same for me, I run a gauge and a light, I use a stock oil pressure switch for the VW engine, they are about 5 bucks at a parts store, it could be the best $5 spent on insurance for your motor, it is always better to see what's going on there with 2 things that monitor the engine than just one.
PostPosted: Sun May 31, 2009 1:33 pm
You have good oil pressure. 10 psi per 1000 RPMs is good.
PostPosted: Mon Jun 01, 2009 9:30 am
My dry sump will run around 30-35 at idle and 20-25 after it warms up at idle. 55-65 Full noise.
"Lets go get stupid"
