It is currently Sun May 03, 2026 9:30 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 30, 2009 12:01 pm
turboblue wrote:
Baddvw wrote:
My transmission used to be a S.S. too, there are certain year S.S. cases that you can convert over to nosecone shifter, I think.
The air cooled SS can be.
80-83 Vanagons.
I've seen thick and thinner rib 091 end shift cases too.
Not sure what version came in what year though........ :?
i think it is where they where sold in the united states,like 83 diesels had 5;43s in some parts of the US and 5;86 in other parts
PostPosted: Tue Jun 16, 2009 3:18 pm
Stock 6 rib ring and pinion is strong but it is not indestructable. Using 35" tires on it sure WILL shorten the lifespan. Usually the demise is directly related to the pinion bearing failing, the nut coming loose or the bearing not fitting tight in the case. Usually all three end up happening sooner or later when you hammer on them. :|
