It is currently Mon May 04, 2026 4:57 am
PostPosted: Fri May 29, 2009 11:56 am
Well I hate to do this but fate is forcing my hand. Me and the old lady are not getting along very well and I feel it's time to move on. So I need to start selling off my toys, tools and I guess my soul to start over. I will update the add with photo's and more items as I dig them out and get photo's so this may take a few days to get it all on here.
First thing is a Chain Drive Frame with auto tranny $1000 Jig built not just knocked togrther, Join the Chain Gang.
Propane Carb KIt or Kits these are the top of the line Modified 450 M&M's not Impco's. There is 2 kits or use together for one big motor how I was going to use them. Each kit can run as big as a small V8 or as small as a stock 1600 VW and every thing in between (5.0 V8 or turbo V6 max on one carb) Runs like fuel injection no more fouled plugs or spitting and spurting of weber/del's.
Cost me $1490 will sale $400 each kit or $750 for the whole lot. Sold
Bus hauler Project 88 Ford BlueBird It's even been titled as a MobleHome at 10,000 lB's so No CDL is needed. Has very low miles starts right up even after sitting a long time Has new A1 virgin tires all the way around and new battery. Has all the power one could ack for a hauler and gets fair MPG @16 it's not air ride. I was going to add a tall gear rear axle with air ride out or a semi to make it get even better MPG because it will only go 70MPH, but that my be in the computer or fuel block.
$1500 The new tires cost more then I'm asking for the whole bus.
Pipe bender, stand and Degree Ring Kit It's a Model 3 Bender
from JD Squared Inc http://www.jd2.com/m3b.htm
I'll take $300 this all together sale's for over $500 new + shipping Sold
A bad day Buggying is better then a good day of most anything else.
PostPosted: Fri May 29, 2009 4:13 pm
Let me know if the bender does not sale. I assumme the die comes with it?
PostPosted: Fri May 29, 2009 4:17 pm
Yes a 1 1/2 tubing die does come with it. I will put you next in line if the deal don't go down
PostPosted: Fri May 29, 2009 4:21 pm
Does the bus have a cummins or brazilian 6.6?
PostPosted: Fri May 29, 2009 6:35 pm
It has a 6.6 turbo Diesel HFM06.6EAA7-DI
I don't think it's a Cummins and don't know about the brazilian part but pretty sure it's a ford engine.
PostPosted: Fri May 29, 2009 6:43 pm
The best way to tell is the valve cover, is there one long or 6 little?
PostPosted: Fri May 29, 2009 9:12 pm
Put me in next on the list for the bender please :)
PostPosted: Fri May 29, 2009 9:14 pm
your up 3rd in line
PostPosted: Fri May 29, 2009 9:38 pm
well put me in 4th in line
PostPosted: Fri May 29, 2009 9:47 pm
It's one long one but I will get a photo or 2 and post them for ya but I'm pretty sure it's not a Cummins
PostPosted: Fri May 29, 2009 9:49 pm
Your there but I just talked to the guy and we have plans to get together early tomorrow.
PostPosted: Fri May 29, 2009 10:10 pm
Ok here are the photo's it has FORD on the valve cover and on the sticker on the valve cover.
Here are better photos http://img35.imageshack.us/gal.php?g=1001876s.jpg
PostPosted: Sat May 30, 2009 1:30 pm
Bender sold to longtravel I hope you get alot of use out of it. It was nice meeting you and your dad hope to see you on the trail sometime when I get my life back on order.
PostPosted: Tue Jun 02, 2009 12:18 pm
Damn dude, sorry to hear all that. Hope you get everything back in order ASAP.
And for anyone interested, I've seen that chaindrive frame in person and it looks great. The pictures don't do it justice! Would be a freakin' awesome project for someone.
Bump for a good seller and a good guy.
Get me that hammer, pronto!
PostPosted: Thu Jun 04, 2009 9:54 pm
Yea I hate it too, I'm sure I'll get back into buggy's it to much a part of life at this point. How id your buggy coming along.
Tony
PostPosted: Sun Jun 07, 2009 8:40 pm
Well I should hope so!
It's almost ready to go. Just need to run brake lines pretty much. Just got done replacing the headgaskets on the engine because it was spraying water out of one of the exhaust pipes (I guess I found the one problem that w/c engines can have that a/c engines can't, lol).
