It is currently Mon May 04, 2026 2:34 pm
PostPosted: Wed May 27, 2009 1:23 am
What would cause this? I'm pretty upset that I spent almost $2000 having this built and this happens.
PostPosted: Wed May 27, 2009 7:05 am
kind of upset? I would be flippin out for 2 grand.
PostPosted: Wed May 27, 2009 7:50 am
oooouch!!!!!!!!!!!
PostPosted: Wed May 27, 2009 8:45 am
Big nut came loose and let the pinion eat the ring gear. Same thing happened to Firebug. :(
Aut Viam Invenium Aut Faciam!
PostPosted: Wed May 27, 2009 8:59 am
Did the pinion nut come loose? Mine stripped out right after I got my buggy on my 6 rib. Didn't get chewed that bad tho.
PostPosted: Wed May 27, 2009 9:06 am
Need to buy the $80 chomoly nut for it the next time.
PostPosted: Wed May 27, 2009 11:45 am
I 2nd that would not use a 6 rib with out one.
PostPosted: Wed May 27, 2009 5:16 pm
i would say that with front end pointing towards the sky as much as yours is it could be easier for it to fall off.lol all jokes aside i hate to see you lose your tranny brad hope you get back together soon.chad :mrgreen:
PostPosted: Wed May 27, 2009 7:07 pm
It had one.
This is a list of whats in it
Weddle Racing Mainshaft Set 3.75/2.36
Weddle Industries 3rd gearset 1.71 (Electron Beam Welded)
Weddle Industries 4th gearset 1.30 (Electron Beam Welded)
Weddle Superdiff
Chromoly Pinion Nut
New Reverse Idler Gear
1st/2nd Operating Sleeve (“Big” reverse-NEW)
Synchronizers (New)
Steel Thrust Plate
Special Needle Bearing for 3rd gear
Special Hardened Washers for 3rd/4th
NEW GERMAN Mainshaft Bearing
Seals, Gaskets, Steel Shift Ball, etc
PostPosted: Wed May 27, 2009 7:11 pm
I talked to Eric today and he is going to fix me up. I guess I can’t complain too much I got 4+ hard years out of it. The only step up I could do is a Weddle ring and pinion but costing $900 I can’t afford it now.
PostPosted: Wed May 27, 2009 8:02 pm
4 years bet they was not easy
PostPosted: Wed May 27, 2009 8:37 pm
u better put a new pinion bearing in when u go back together,pinion bearing is 80 chrome moly nut is 35,jus bought one,pinion bearing could have went bad,jus a little slack is all it needs
PostPosted: Thu May 28, 2009 2:01 pm
Dang, 4 years?
I thought maybe it was a fresh.
That tranny don't owe ya too much.......... :mrgreen:
PostPosted: Fri May 29, 2009 7:18 am
I was going to say the same thing. Always put a new pinion bearing in them, and nut. I hope your Bearing did not spin in the case.
PostPosted: Fri May 29, 2009 9:57 am
Eric's going to put it in a side shift case for me. He said they have thicker ribs and my origional case is probably shot.
PostPosted: Fri May 29, 2009 4:54 pm
all of ours are in the S.S. cases. Much better case.
PostPosted: Fri May 29, 2009 5:44 pm
i sent my 5 rib case out west and the guy put gussets on it and put a steel sleeve in the pinion bearing hole and a nice lock to keep from spinning the bearing
PostPosted: Fri May 29, 2009 5:48 pm
where did u send that 5 rib to those mods done :?:
PostPosted: Fri May 29, 2009 6:42 pm
D.K. machining& fabrication 562-864-9618 or 310-864-9618
PostPosted: Fri May 29, 2009 6:49 pm
PostPosted: Fri May 29, 2009 9:37 pm
My transmission used to be a S.S. too, there are certain year S.S. cases that you can convert over to nosecone shifter, I think.
PostPosted: Fri May 29, 2009 9:48 pm
This is the same type SS I have. I hope it works I paid $25.00 for it :D
PostPosted: Fri May 29, 2009 9:56 pm
can you get more??
PostPosted: Sat May 30, 2009 12:00 am
I wish
PostPosted: Sat May 30, 2009 11:32 am
The air cooled SS can be.
80-83 Vanagons.
I've seen thick and thinner rib 091 end shift cases too.
Not sure what version came in what year though........ :?
