It is currently Mon May 04, 2026 12:38 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 19, 2009 9:57 pm
Its a miracle,ive got the best brakes ever now.All i had to do was compress the caliper pistons all the way in and clamp them down,then let the power bleeder do the rest.A man can learn a lot,or little in 3 days of work,LOL.Thanks guys.
PostPosted: Tue May 19, 2009 10:38 pm
Glad to see you got it figured out.I got two buggy's down here that needs done.LOL So the calipers was holding air in them?
PostPosted: Wed May 20, 2009 12:57 am
Glad to hear it man, not that complicated of a system. Figured with enough head scratchin and beer/booze we'd get r figured.
PostPosted: Wed May 20, 2009 6:50 am
I may try that,,do you open the bleeder as you are compressing the piston ,or push the fluid ( with air) back upline then bleed?
PostPosted: Wed May 20, 2009 9:46 am
i would think you would open the bleeder valve then compress the piston,jus open a little and compress slow
PostPosted: Wed May 20, 2009 9:56 am
I rode mine for a bit and they became one pumpers. Re-bleed after that short test and you can't pull the cutters an 1/8th inch now after the second bleed. Rode it again for half hour after that and brakes never softened up any. I didn't even remove the calipers the second time just cracked the bleeders and went. The second time however I did NOT break the cap loose on the master cylinder. I pressurized the system and bleed it out then unhooked the sprayer and put the cap on the valve stem. Thanks KY boys :)
"Lets go get stupid"
PostPosted: Wed May 20, 2009 12:58 pm
You're welcome. 8)
PostPosted: Wed May 20, 2009 7:12 pm
I hooked the bleeder up and then i stuck a screwdriver between the pad and the piston and compressed it back all the way and stuck a extension in there to hold it in and then pumped the bleeder up and broke the bleeders loose,pumped the pedals a few times,shut down 1 bleeder and worked the ST.brakes and pedal again,then the opposite side.Let the bleeder run until you get a solid pedal with the bleeders closed and then release the air on the pressure bleeder.
PostPosted: Wed May 20, 2009 9:25 pm
I tried your idea about pressing the piston in and WOW,,,it works,,I pressed it back and held it in place with a socket and bled the tube in a jar method, and I am very impressed,, BM,,your a genious :wink:
PostPosted: Mon Jul 13, 2009 10:11 am
Update: the pressure bleading method didn't do anything but make a huge mess for me. One thing that I hadn't done when I started this thread was to fully adjust the shoes out to the drums. Once this was done and the brakes were bled the normal way, I had tons of brakes. Although I did find out that my Neal turning brakes need to be rebuilt. Which could account for the issues from the pressure bleeding event. Oh well. Currently planning on discs after I get past the dmv.
Thanks for the replies.
PostPosted: Wed Sep 02, 2009 10:32 am
One thing i didn't see mentioned earlier in the thread was bench-bleeding. Most people think to bench-bleed the master but not the steering brakes. I haven't had trouble with steering brakes since using this process.
