It is currently Tue May 05, 2026 2:15 am
PostPosted: Sat May 16, 2009 2:51 pm
Just wanted to ask if it is possible to convert my swing axle torsion to a irs torsion i mean can i just make tabs bor the trailing arms or do i just need to change my torsion one of my buddys said we could just weld some mounts but im not sure any help would be great
SHAKE AND BAKE!!!!!
PostPosted: Sat May 16, 2009 3:05 pm
yea you can buy the brackets to weld in yours and convert it over just make sure that you get them aligned right. they also sell a jig for welding them in.chad :mrgreen:
PostPosted: Sat May 16, 2009 3:07 pm
will i have to change spring plates? and do you know where i could buy that stuff?
SHAKE AND BAKE!!!!!
PostPosted: Sat May 16, 2009 3:26 pm
You can re-use your spring plates, but you will have to shorten and redrill them. Thats actually a slick way to go , then you dont have the "stump-catcher" stickin out from the torsion like regular IRS.
PostPosted: Sat May 16, 2009 4:44 pm
anyone know where i can get this jig and some premade mounts
SHAKE AND BAKE!!!!!
PostPosted: Sat May 16, 2009 4:50 pm
search on ebay ...will find a pic of them
PostPosted: Sat May 16, 2009 4:55 pm
mitchles vw service center just outside of tuscaloosa should have weld on adapters not sure about the jig but i have seen it on the samba and in magazine ads for sale also d@b body shop just outside of rogersville should have the adapters but is usally a little more expensive than mitchles but not allways :)
PostPosted: Sun May 17, 2009 12:38 am
thanks guys will call mitchells monday
SHAKE AND BAKE!!!!!
