It is currently Sun May 03, 2026 4:05 pm
 Post subject: Snap Mounts?
PostPosted: Sun May 10, 2009 1:35 pm
I was thinking of using some vinyl I have to make a cover over the front of my buggy, kind of like a boat cover. Thought I'd use snaps, anyone know of any that use bolts? I've used the ones with screws b4 but can't recall bolt on ones. Thanks, Jason
 Post subject: Re: Snap Mounts?
PostPosted: Mon May 11, 2009 10:00 am
do you really want to drill the tubing full of holes? maybe consider grommets and zip ties.
PostPosted: Mon May 11, 2009 12:52 pm
Industrial strength Velco.
It's available.
PostPosted: Mon May 11, 2009 6:57 pm
I want to weld on a few tabs, then bolt on flat stock with the snaps.
PostPosted: Tue May 12, 2009 8:30 am
if you're willing to weld tabs on you might consider this stuff. i made my body with it. i used the fat head pop rivets. you can bend it in a brake and it holds it's shape, doesn't rattle, not brittle in the winter, no paint to peel or chip, won't rust, etc. i love the stuff.
http://www.allstarperformance.com/product.htm?prod=155
