It is currently Mon May 04, 2026 11:09 am
 Post subject: BUGGY WONT RUN
PostPosted: Mon Apr 27, 2009 9:24 pm
NEW PLUGS AND WIRES I DONT KNOW WHATS WRONG WITH IT MOVED THE GAS TANK FIGURED IT WASENT GETTING ENOUGH GAS BUT I WAS WRONG AND ALSO ON THE FAN SHROUD WHERE THAT LITTLE THING IS ARE THEY SUPPOSE TO BE AIR COMING OUT OF THAT?
Brandon
 Post subject: Re: BUGGY WONT RUN
PostPosted: Mon Apr 27, 2009 9:52 pm
what carb you running on that how about intake leaks what little thing are you talking about the tube on the side of the shroud it should be hooked onto the little pipe on your oil fill so it blows cool air in to help keep the motor cooler i think also points or electronic distributer you have spark if you have spark spray carb cleaner or starting fluid around your intake boots and base of your fuel rail where it bolts to the head i had this problem where it would not start if you didnt do this may need new gaskets as far as your carb check your idle jets if it or they are clogged its hard starting when its cool
PostPosted: Mon Apr 27, 2009 10:10 pm
well it wont start and that little thing sorta looks like the thing that the dip stick goes in and its a 34 pict solex
Brandon
PostPosted: Tue Apr 28, 2009 6:59 am
Well you have to be more specific as to whats going on for help. Is it cranking and poping? Then your timing might be off, Is it cranking and just spudering? Then prob have a fuel or ignition prob.
PostPosted: Tue Apr 28, 2009 8:25 am
Some other questions that might help..
Have you ever had it running?
Did it just sit all winter and wont start this year?
Did you change anything since it last ran?
PostPosted: Tue Apr 28, 2009 9:17 am
Do you have a fuel pump hooked up? The only time I've ever moved a gas tank to get one to run is when the fuel pump went out and I let the carb gravity feed by moving the tank higher than the carb.
Is the thing with the air coming out of it on the top passenger side corner of the fan shroud? If so, you can block it off. It is a line that the Beetle uses that you don't need on a buggy, most of the time they are removed and leave a little spot that looks like a dipstick might fit in.
Aut Viam Invenium Aut Faciam!
PostPosted: Tue Apr 28, 2009 12:46 pm
sorry about not bein more specific i dont know much about buggys ive just had it about 2 months no i have drove it since winter u have to hold the gas to the floor to get it to start and sometimes it still wont start and if it does start it will backfire and shut off and when your giving it gas it will backfire like a flame and yes it has ran since then and no i havent changed anything
Brandon
PostPosted: Tue Apr 28, 2009 2:43 pm
That explains a lot more. I am sure you will get some great advice from people smarter than me but I will give you my initial ideas. If you are getting backfiring and a flame, I would start with the order of the new wires and make sure nothing got cross or mixed up. Then i would check the timing.
If it is backfiring and throwing a flame, you have fuel and spark, it is just not happening at the right time.
PostPosted: Tue Apr 28, 2009 7:36 pm
also there is like steam i guess is what you can call it that comes out of the place where u put the oil in once it shuts off if u take the oil lid off and it smokes out of the exhaust
Brandon
PostPosted: Wed Apr 29, 2009 7:15 am
Yeah sounds like timing. The white "smoke" coming out of the oil cap means its Hot. Do you have an oil cooler?
PostPosted: Wed Apr 29, 2009 8:14 am
Blowby, compression is getting past the rings. Time for a hone and rering in the very near future.
What is your timing set at?
Did you clean the carb after it sat all winter?
PostPosted: Wed Apr 29, 2009 12:59 pm
no i didnt clean the carb it didnt set all winter i let it run about once a week and nope no oil cooler right now i guess the timing it like it always was i dont know much about timing
Brandon
PostPosted: Wed Apr 29, 2009 3:12 pm
it hasnt got an oil cooler,i hope its got the stock oil cooler,if not it wont last long
PostPosted: Wed Apr 29, 2009 4:23 pm
i mean its got a stock oil cooler but no a external one
Brandon
PostPosted: Sat May 02, 2009 2:40 pm
so u got it fixed and now ur not gonna sell it,what was wrong with it??
PostPosted: Mon May 04, 2009 10:56 pm
he adjusted the valves some and it was out of time thanks for all the help from on here
Brandon
