It is currently Sun May 03, 2026 5:37 pm
 Post subject: Accusump,,,pros and cons
PostPosted: Tue Apr 28, 2009 2:43 pm
What about something like this,,,cheaper than dry sump and easier to install. But still cheap insurance,,,
http://cgi.ebay.com/ebaymotors/CANTON-3 ... ccessories
PostPosted: Tue Apr 28, 2009 4:04 pm
I have no empircal data to pull from however I have read that they do work.
PostPosted: Tue Apr 28, 2009 6:45 pm
I got one for my buggy, but haven't installed yet.
PostPosted: Tue Apr 28, 2009 10:41 pm
My buddy Wade has one on his buggy . the v8 CD. it's a killer concept. I know on some long LONG hills like left side of the wall in blairsville you sometimes loose oil pressure .It's long and STEEP
PostPosted: Fri Aug 14, 2009 8:54 am
Im putting one on my buggy now,,,any pointers?
PostPosted: Fri Aug 14, 2009 2:54 pm
I've been running one for 3-4 years now, and I haven't even seen so much as a flicker from my oil light. I would mount it where you can reach it from your seat so you can shut it off or open it up when you start or shut off your buggy. You will never "dry start" your motor again! I would't have a buggy with out one.
PostPosted: Fri Aug 14, 2009 3:03 pm
Im getting that automatic electric valve too.
PostPosted: Thu Sep 03, 2009 10:03 pm
Love mine .only seen the pressure drop one time and it kicked in. no spun bearings.I have the big one 3qt.I wish i would of had it on my old rail i would of saved two teardowns at least.
PostPosted: Thu Sep 03, 2009 10:07 pm
I got mine all hooked up but I think I got a switch that is for too much oil pressure,,I ordered a lower pressure switch.....and up'd my idle too. but on high idle and wide open climbing it dumps fine...I am wondering if my oil pressure is too low and if I need to use more lucas?
PostPosted: Thu Sep 03, 2009 10:24 pm
Mine has shrader valve in one end and that's were i set the press. 20 psi
