It is currently Mon May 04, 2026 11:02 am
 Post subject: Nylon brake line
PostPosted: Tue Feb 03, 2009 12:52 pm
Does anyone have experience with using nylon brake line?
Anyone have a humble opinion?
http://www.appletreeauto.com/detail.aspx?ID=12605
I'm a chicken, not a turkey
 Post subject: Re: Nylon brake line
PostPosted: Tue Feb 03, 2009 1:47 pm
I would use steel for offroad. Plastic tubing can get snagged by so many different things and be broken at the worst time. Theres this sinking feeling you get when your rolling down a steep hill and you push the brake pedal and it goes to floor. Need I say more?
PostPosted: Tue Feb 03, 2009 2:11 pm
I know it doesn't matter much but it also states CAN NOT be made legal for road. My personal opinion is that I want my brakes at LEAST dot approved. Thats about the worse thing that can happen in the woods come rumblin tumblin down scooby with no brakes.
"Lets go get stupid"
PostPosted: Tue Feb 03, 2009 3:41 pm
I agree with Odyknuck, I would rather use steel brake lines too, that what I am running, and uses stainless flex from the rail to the calipers.
Here's what I used on mine.
http://www.jegs.com/i/JEGS/555/63030/10002/-1
You can also get them in powercoat silver or black.
And these is what I used on the lines from the rail to the calipers, I did not get them from Jegs but something very similar to it. I got them from the local race car shop and the brand name is Fragola and they are the best, that is what they run on their late-model cars for their clutch and braking systems at the wheels.
http://www.jegs.com/i/JEGS/555/635000/10002/-1
PostPosted: Sun Apr 19, 2009 8:26 pm
Do you have a dbl bubble flare or do use stadard flare?
