It is currently Mon May 04, 2026 8:40 am
PostPosted: Thu Apr 02, 2009 9:13 am
2276 with VZ 15 cam, 044 heads. dual 44's
Right now we have
55 Idles
140 Mains
200 ac's
F7 Tubes
"Lets go get stupid"
PostPosted: Thu Apr 02, 2009 5:22 pm
Looks good maybe 150 or 155 mains well run cooler in new engine
PostPosted: Thu Apr 02, 2009 9:38 pm
ive always started out
55 idles
135 mains
175 air
f7 or f11
and the pump valve should be a 0
the valve in the bottom of a weber
PostPosted: Wed Apr 15, 2009 2:10 am
Something I was once told.
Venturis are usually 2-6 mm smaller than the intake valve size.The smaller venturi the more bottom end torque.
Fuel pressure is critical. 2.5 psi.
Float level 10-11 mm. Start with 10.5 mm
Emulsion tubes F-11 are the most popular
Idle jets 1.6xs the size of the venturi.
Mains 4.1-4.3 xs the size of the venturi. a little rich is better than too lean.
Air 1-2 sizes larger than the main
1500 -2000 rpms is controlled by the idle circuit
2000-3000 is fed by the idles and the mains
idle jet size and float level are what you use to tune this rpm range.
3000-4000 is fed from the mains
4000-5000 from the mains and airs
acc pump jet use the smallest you can and still accerate. Adjusting the rod can make a significant change.
It seems to work ok for most engines with snmall to medium sized valves.
How hard does the VZ 15 cam pull in your engine? I have only used it in a 1776 to 1915 engines and liked it. I want to try one in a 2386 I am building for someone.
PostPosted: Wed Apr 15, 2009 3:32 am
thats actually a buddies engine. we ended up with
55 Idles
175 AC
135 Mains
F7 Tubes
Thanks Chris on the 135's just about where it needs to be.
I also run the VZ15 on my 2332. I ran a 14 last year, I have not really had a chance to run the new motor much so can't comment yet but the couple times I called on power there was no lack. In my motor right now I have
55/200/145/F7's 110 Race Fuel 100%
PostPosted: Wed Apr 15, 2009 7:01 am
i ended up changing my idles to 47 and my mains to 150 it was loading up on the bottom endso i went a little smaller on my idles
PostPosted: Wed Apr 15, 2009 9:32 am
That combo does not sound right. 47s are really lean. Is it possiable that your mains are to rich and you had to compensate with the smaller Idels?
PostPosted: Wed Apr 15, 2009 12:26 pm
Have you double checked fuel pressure and the float levels?
PostPosted: Wed Apr 15, 2009 3:26 pm
i had 50 idle jets in itwent to 47 and it runs perfect,im not gonna change it back to 50 because it would load up a little,idling up a steep hill
PostPosted: Wed Apr 15, 2009 7:12 pm
If you feel it's perfect, it probably is. :wink:
PostPosted: Fri Apr 17, 2009 9:43 pm
Hey Kyle
what have you found out?
PostPosted: Sat Apr 18, 2009 2:26 am
wish i could idle up a steep hill, that's got to be alot of fun :D :D
PostPosted: Sat Apr 18, 2009 8:42 am
perrib wrote:
Hey Kyle
eh? mine is perfect. I think you guys were talking to Chris about the 47 :)
PostPosted: Sat Apr 18, 2009 7:10 pm
Kyle wrote:
perrib wrote:
Hey Kyle
For some reason I thought you were asking for jetting help not stating a good place to start.
In that case how do you like the cam in the 2332?. I want to build a 2386 with a VZ 15 cam. I know how it runs in an 1835. Does it still pull hard at 4000-5000 rpm with the larger 2332 displacement?
PostPosted: Sat Apr 18, 2009 7:21 pm
In my opinion the VZ-15 cam works better in a smaller displacement motor. There are other choices that work better in the larger motors. The FK and W series. 1.4 Rockers are a must to take full advantage.
PostPosted: Sat Apr 18, 2009 11:01 pm
I like the VZ15 in mine. Just personal preference again. I think I have way more bottom end than most, but the VZ series I supposed to wear faster than a "proper" FK with 1.4's. I like my setup A LOT.
PostPosted: Sun Apr 19, 2009 12:08 am
Personally for the driving I do, I really like my Weber version of the VZ 25 for my 2180. I had the lifter bores sleeved at around 20,000 miles. They should of been done before that. The 2386 engine I want to try the VZ 15 in is for a rail with stock 12 volt gearing. I was hoping the less duration would still let it pull hard with the stock 3/4 gears. I never drove the 1835 or the 2180 with anything other than 1.58 and 1.26 3/4 gearing so I have nothing to go by. I have a DDS 11 1101 cam in my 2386 It was Dean Lowrys version of the FK 8 it had more duration and lift but not quite an FK 10. It is also a very torquey engine.
