It is currently Tue May 05, 2026 1:59 am
PostPosted: Sun Aug 19, 2007 7:09 pm
i have a 2332 with dual 44s 44x39.5 cb heads 11.0 to1 compression will a coustom ground cam with 1.25 rockers will a vw fuel pump push that much fuel
PostPosted: Sun Aug 19, 2007 8:15 pm
The stock pump will supply enough gas for the carbs however its the pressure you have to be concerned with. Put a pressure regulater in line and set it at 2.5 to 3 PSI.
