It is currently Tue May 05, 2026 12:44 am
 Post subject: trans qustion
PostPosted: Sun Apr 05, 2009 10:42 pm
my 6 rib trans keeps popping out of reverse and has a slight grinding noise when it dose so.....
the rest of the gears are fine
any help....??
thanks
tanner
 Post subject: Re: trans qustion
PostPosted: Sun Apr 05, 2009 11:05 pm
is the shifter adjusted so it goes all the way in ? make shure of this ,take the shifter rod loose to check it if it is in all the way and it still jumps out ,PUT IN A NEW REVERSE GEAR
PostPosted: Sun Apr 05, 2009 11:19 pm
how hard is it to replace the revrse gear,,,,, could i do it... or not..??
PostPosted: Mon Apr 06, 2009 6:14 am
first if you still have rev. no need to replace it. you have a linkage problem. take your shifter lose and slide it as far forward as you can. see if this helps. did you have it before powder coating? is it a stock shifter? let us know
PostPosted: Mon Apr 06, 2009 9:07 am
the guy who was going to powder coat oven broke and wasnt going to be done with it in time for d&k so i had to spray paint it..... for now
and ill try with unhookin the linkage ill let you know
PostPosted: Mon Apr 06, 2009 3:33 pm
just cause it still works doesnt mean its any good ive have pulled them apart and all the teeth were almost side ways on the little gear and the teeth on the 1 2 slider were half way gone it could be an external shift linkage problem but it could be the linkage inside has moved also
PostPosted: Mon Apr 06, 2009 9:04 pm
you where right it was the lingage i got it fixed thanks
PostPosted: Mon Apr 06, 2009 11:25 pm
ain't this what I said 3 or 4 post ago
PostPosted: Mon Apr 06, 2009 11:26 pm
PostPosted: Tue Apr 07, 2009 6:18 am
you can lead em to water rock, but..........
:mrgreen:
"Lets go get stupid"
PostPosted: Tue Apr 07, 2009 7:21 am
Tanner followed Rock's advice and checked the linkage,,,good job Tanner,,,see you at the Easter Hill Climb
