It is currently Tue May 05, 2026 12:48 am
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Codename: Solo
PostPosted: Wed Mar 18, 2009 2:06 pm
:mrgreen:
Mota is blanced!! Woohoo that was the last holdup. Should be ready for D&K now yea!
"Lets go get stupid"
PostPosted: Fri Mar 20, 2009 11:20 am
Its basically all together. Got a few more things to put on like a toolbox mount and oil cooler mounts. Going to get motor together this coming up week still need to get me a set of rings, then plumbing and wiring and should be ready to climb woo. Phone was dead last night I will grab some pics tonight.
Kyle
PostPosted: Mon Mar 23, 2009 10:30 am
Heres a few pics. Almost ready. Got to get the front end together and put motor in. Lots of little dumb stuff oil line pluming, brakes, etc....
PostPosted: Mon Mar 23, 2009 11:44 am
codename soslow
PostPosted: Mon Mar 23, 2009 1:57 pm
purplerail wrote:
codename soslow
codename 4 wheeler aka brett the woodsquad.com member :)
PostPosted: Mon Mar 23, 2009 3:30 pm
HAHAHAHA was not riddin bitch like you
PostPosted: Mon Mar 23, 2009 7:32 pm
:shock:
PostPosted: Mon Mar 23, 2009 9:57 pm
I rode bitch out of necessity, you WERE a bitch on your quad by choice :)
Next ride lets see what the definition of bitch really is....that is if you can still get your buggy out of the garage haha...you started it
PostPosted: Mon Mar 23, 2009 10:01 pm
tender arent ya
PostPosted: Tue Mar 24, 2009 7:32 am
purplerail wrote:
tender arent ya
as a good NY Strip hahaha
PostPosted: Tue Mar 24, 2009 1:59 pm
the big guy is still riding his 4 wheeler that is a shame when he's got a bad ass buggy to ride.maybe that buggys to much for him?
PostPosted: Tue Mar 24, 2009 5:39 pm
freshnig up the motor be ready in a few weeks
PostPosted: Wed Mar 25, 2009 2:29 am
Hum,,,,D&K bound? :mrgreen:
PostPosted: Wed Mar 25, 2009 11:23 pm
don't get your hopes up mutt. hahahha
PostPosted: Sun Apr 05, 2009 10:56 pm
Got the motor all together. Greg built a fine machine once again.
Specs 2332cc
84mm crank
94mm cylinders
5.6 H-Beam Rods
042 Mofoco heads (40x35.5)
VZ15 Cam
Chromolly pushrods
CB Dry Sump
BMD Dry Sump Serpentine System (sand sealed)
11.88:1 Compression
Went to Drews today and got a bunch of parts. Also picked up another set of used 4 plys. Got just about every part I need to finish the buggy, and all the AN fittings from Jegs, trip two will be back tomorrow all my tanks ones are wrong! We got the cobra running tonight and took it for a test drive so its pretty much going to be building like crazy for 3 straight days then off to D&K! Looks like christmas at the buggy garage.
PostPosted: Sun Apr 05, 2009 11:00 pm
you mean to tell me you went to all that trouble and did not go with strait cut cam gears :shock: DAMN IT MAN
PostPosted: Sun Apr 05, 2009 11:45 pm
Gotta agree with you here, Rock. Dry sump pump and stock style cam gears dont get along too well, I've been told. Luckily it is the small pump, maybe it'll be ok. Hope so.
PostPosted: Mon Apr 06, 2009 7:51 am
I ran stock gears with that same pump for one year with no problems,but tore it down and put straight cut in the first winter to be safe.
PostPosted: Mon Apr 06, 2009 8:37 am
i was told by cb unless you are running a turbo application, straight gears are not necessary.
pretty sure i even started a whole new topic on this very matter!
PostPosted: Mon Apr 06, 2009 9:28 pm
Good lookin' rig little buddy, but let me tell you mofoco=mof*ckinjunk!!! pm me ur number, ill send you a pic of mine....
PostPosted: Mon Apr 06, 2009 10:08 pm
Man that's a sweet ride i wish i had a single seater maybe if someone would take my current buggy off my hand :D jeff clay dont tell me the mofoco heads are junk i just bought the 042 also
PostPosted: Mon Apr 06, 2009 10:10 pm
I meant please dont tell me that i dont know a whole lot about mofoco
PostPosted: Mon Apr 06, 2009 10:20 pm
i got 042 mofoco heads on my car and they been on there 3 yrs,never took them off
PostPosted: Tue Apr 07, 2009 6:01 am
yep mofoco gets a thumbs up from me.
I did all the work to the spindles last night to. welded up the KP gusset kit, then because I run heim joints for tierods I had to drill out the spindles to 5/8ths. This leave very little material left around the spindle hole so I took some round bar and heated it up an bent it all around then welded solid. Spindles and stuff are one of my favorite cool looking things.
got a bunch done last night. frontend is on, just going along and making some mounting tabs for oil coolers, wiring, etc. I picked up a complete waterproof 6x6x6 work box from local electric sales shop. Got the watertight fittings to feed the wiring out of the box also. pretty trick setup and got it all for 30.00 I need to get some gaskets and stuff so I can bolt the carbs on and get it ready to hopefully make some noise tonight.
PostPosted: Tue Apr 07, 2009 10:41 am
never had any problems with MOFOCO heads.I have on the other hand built motors that had a lot of wear caused by pressure from a slash cut gear
and you can call the Bergs and tell them I said so :lol:
