It is currently Mon May 04, 2026 11:57 am
 Post subject: cooling problem
PostPosted: Mon Mar 30, 2009 10:16 pm
will i need a radiator shroud behind my fan. At u ride it a while it start to run hot .4 core alum.rad. good fan NO shroud .I think that my problem what u all think 160 thremstat
If it feels good, hold it to the floor and pour it to it!
http://www.dandkoff-roadpark.com/FORSALE.html
 Post subject: Re: cooling problem
PostPosted: Mon Mar 30, 2009 10:31 pm
I think a shroud is recommended,,,also if you are running an automatic tranny,,,additional trans oil cooler.
PostPosted: Tue Mar 31, 2009 2:06 am
get you some fans out of a ford touras v6. they have dual fans with high speed motors. they just mount on the radiator the shroud is built into the fan setup. i used to run that setup on my v6 rock crawler works real good. 20.00 at junk yard.
"Lets go get stupid"
PostPosted: Tue Mar 31, 2009 2:33 pm
Are the fans pushers or pullers? I had a problem like this before, my fans were pushing not pulling. I switched them to pullers and had no problems since.
PostPosted: Tue Mar 31, 2009 2:36 pm
reversible. switch the wires :)
PostPosted: Tue Mar 31, 2009 6:54 pm
Gizmo, I got a big single electric fan assembly (shroud, fan, motor) out of a late model sumthin or other I worked on. Cant remember what I took it out of but it looks just like the ones they use in v6 and v8 mustangs and those work great for street n strip cars with healthy motors in them.
You want me to bring it down Easter weekend? I'll trade you for a night's worth of campin!
:D
PostPosted: Tue Mar 31, 2009 11:15 pm
I have been try it all ,Try it out wed. night and see how it does.
PostPosted: Wed Apr 01, 2009 1:52 pm
You need a shroud that covers the whole rad we had this problem with v8 cd in Al
this dude Ken made one out of sheet metal it covered the whole radiator that fixed the problem
PostPosted: Wed Apr 01, 2009 3:12 pm
This what I did with mine. I had to offset the fan due to Turbo tubing clearence however when the fan is running it pulls from the entire radiater surface.
PostPosted: Wed Apr 01, 2009 5:39 pm
Made mine out of sheet metal a couple weeks ago.
PostPosted: Wed Apr 01, 2009 9:00 pm
Ah! you got to use the 4 mounting boss's on yours. I could not use mine because the outlets needed to face the front of the Buggy, however they came in handy for mounting the top gromments to mount the Radiater.
PostPosted: Thu Apr 02, 2009 11:34 pm
Odyknuck wrote:
This what I did with mine. I had to offset the fan due to Turbo tubing clearence however when the fan ids running it pulls from the entire radiater surface.
Ifix mine up this way here with a few more things i believe it will work. one more problem now the air blowing on my gas tank and heating it up,O well
PostPosted: Fri Apr 03, 2009 6:54 am
Heating up your gas tank is prob not good. I mounted mine up like this. Put the gas tank first then the rad so its pulling the hot air away from the rad and also blowing air over the engine.
PostPosted: Fri Apr 03, 2009 3:33 pm
Thats what i did too. Its a honda civic rad with fan and shroud.
PostPosted: Fri Apr 03, 2009 9:56 pm
Thanks for all the info i think its going to work all :D right
PostPosted: Fri Apr 03, 2009 10:35 pm
A proper fan shroud will make all the differance.
Don't change the thermostat to 160. It will shorten the dwell time of the coolent in the radiator, read not get cool enough.
Was it overheating, boiling over or percolating or was the temp guage just saying it was getting warm?
I dumped a ton of $$ into a 1968 Camaro to keep it cool because the temp guage said it was getting hot all the time, 220-230 deg. The real problem was the top of the line Sun temp guage I was using was NFG. It read 20 to 30 deg too hot all the time.
Food for thought
PostPosted: Mon Apr 06, 2009 8:59 pm
Food for thought
Mike it is on the money now 160 ther. was the biggest problem, It's cool like all buggy rider yell. FIXED
