It is currently Tue May 05, 2026 2:10 am
 Post subject: rear tire adj.
PostPosted: Tue Mar 31, 2009 4:37 pm
setting up my new single seat rear end. my old buggy i put one washer on one side and one on the other side of my trailing arm but this one looks like the wheels are facing out alittle any idea how to set it right? i guess i could redrill my spring plate single hole.
 Post subject: Re: rear tire adj.
PostPosted: Tue Mar 31, 2009 4:47 pm
thats the only way. changing those washers around will affect camber a bit, but to get your toe right you gotta line your holes up or redrill.....get busy!
"Lets go get stupid"
PostPosted: Tue Mar 31, 2009 8:26 pm
the washers go on the same side..outside.
PostPosted: Wed Apr 01, 2009 1:21 am
all of us around here run 1 and 1
PostPosted: Wed Apr 01, 2009 6:58 am
Then you all would be wrong. Putting a washer inbetween the arm and the pivot cup does nothing except make your axle shorter. It does nothing for caster, camber or toe. Both washers should be on the outside of the bushing exactly where Dr. Porche designed them to be at.
PostPosted: Wed Apr 01, 2009 10:19 am
better look in your VW manual there fellows, no ones wrong, ou can put them 1 and 1 or 2 on both :mrgreen:
PostPosted: Wed Apr 01, 2009 8:12 pm
The question was and is in regard to toe adjustment. Not trans/trailing arm centering. I know the book too Kyle.
PostPosted: Wed Apr 01, 2009 8:17 pm
I will admit, I have been schooled, I always thought its was 2 on the outside no matter what. I've never seen that diagram. (bogus homemade detail from eastern Ohio??) lol. Learn something new everyday.
PostPosted: Wed Apr 01, 2009 11:15 pm
lol yea...i said long posts ago you had to redrill or realign the spring plates to the arms to get toe alignment....i was just showing the diagram cause it was said 1 and 1 was wrong smile mike :mrgreen:
i was i could diagram that good andrew haha!
PostPosted: Thu Apr 02, 2009 6:50 am
If you must re-drill the arms to get the toe correct I'm thinking the arm is bent. I would check that first and if your not measuring with a center line down the lenght of the buggy, probably not getting a accurate reading.
