It is currently Tue May 05, 2026 2:22 am
 Post subject: stub axle bearings
PostPosted: Sat Mar 28, 2009 2:28 pm
rear bearings are worn out. when i tore down it has the ball type bearing for the inner and outer. i am assuming that this means that it is prior to 1969 setup. question is can i change to the roller style outer bearing and use the same spacers that i already have? is there any reason why i should or should not change to the newer outer bearing?
 Post subject: Re: stub axle bearings
PostPosted: Sat Mar 28, 2009 2:41 pm
if it had ball type bearings in the inner and outer,its wrong,if i can remeber right,ball bearing goes inner and roller goes outer,i may be backwards,auto zone has them and can tell you
PostPosted: Sat Mar 28, 2009 2:45 pm
ok, but when i looked it up it on cb performances web site it shows only one part # for the pre 69 t1? it listed an inner and outer for the 69 and later. thanks, jd
PostPosted: Sat Mar 28, 2009 2:48 pm
swingeaxle or irs???
PostPosted: Sat Mar 28, 2009 2:51 pm
sorry, irs
PostPosted: Sat Mar 28, 2009 2:59 pm
all the ones ive ever messed with is 2 different bearings,,timken bearing inner part number is ;;206WB;; outer is MA1206EF
PostPosted: Sat Mar 28, 2009 3:04 pm
thanks
PostPosted: Tue Mar 31, 2009 9:01 am
SKF part #'s
6206 C3 for the ball brg.
NU 206 ECP/C3 for the roller brg.
DICHTOMATIC TCM 43 X 62 X 10 SC (replaces 16939) for the seals.
Mike
Got Honda?
PostPosted: Tue Mar 31, 2009 10:36 am
VW part numbers:
113 501 283 is inner and a ball bearing.
113 501 277 is outer and a roller bearing.
113 501 315 is the seal number.
Two required per side.
PostPosted: Fri Apr 03, 2009 2:57 am
i just did mine tonight the ball one is inner
