It is currently Sun May 03, 2026 7:08 pm
PostPosted: Tue Feb 03, 2009 8:43 pm
i have a f350 deisel that is pumping fuel out of a tube which runs from the back side of what i guess would be like a throttle body (where the carb is on gas motor -- i no nothing about deisels) . Does anybody have an idea??
PostPosted: Tue Feb 03, 2009 11:16 pm
What year is the truck??
PostPosted: Wed Feb 04, 2009 1:32 pm
Yeah, what year?
7.3 has a fuel filter, heater combination about in that spot.
I had a sensor go bad and leak from that device.
Think there are o-rings on those feed lines to it too.
This is a premier site for Ford Navistar diesel engines.
http://www.thedieselstop.com/forums/
Just pick the appropriate forum and do a search.
PostPosted: Thu Feb 05, 2009 12:09 am
sorry , its a 1999 with a 7.3 -- its my dads girlfriends truck, and im trying to save her a trip to the shop if i can fix it
PostPosted: Thu Feb 05, 2009 12:40 am
thanks gary,
I did a search on that site which told me the tube is a drain for the filter housing. It says that there should be a yellow drain handle back there and it is a common problem for the o-rings to go bad. I printed out a step by step guide on how to change them.
Does it sound like im on the right track to you guys????
PostPosted: Thu Feb 05, 2009 11:18 am
Yes you are on the right track, remember it is very important that you pre-oil your o-rings when you put them on, that way it will not rupture on you when you put it together. Let us know how it went.
PostPosted: Tue Mar 17, 2009 1:36 pm
sorry it took so long to get back to this. -- i took it apart, spent 62 cents to replace the o-rings , put it back together and it fixed the problem
thanks gary and chad
larry
PostPosted: Wed Mar 18, 2009 9:56 am
Once again Turbo you da man :D
