It is currently Tue May 05, 2026 5:11 am
 Post subject: ?D O M tubing?
PostPosted: Mon Feb 23, 2009 6:29 pm
what is the best tubing 2 use for the frame d o m or something else??
 Post subject: Re: ?D O M tubing?
PostPosted: Mon Feb 23, 2009 8:07 pm
For the money DOM is the best structural tubing. Chromolly is the best untill you consider the cost. ERW tube is OK for some applications, low structral loads and bracing.
For a buggy chassis, 1 1/2", .095 DOM is plenty good.
PostPosted: Wed Feb 25, 2009 1:02 am
chromolly has to be tigged also right?
"Lets go get stupid"
PostPosted: Wed Feb 25, 2009 9:53 am
I built mine out of Galvanize conduit
PostPosted: Wed Feb 25, 2009 3:28 pm
erw is what MOST BUGGYS are built from some may use pieces of dom or crom. but if you use the right size erw its tuff & safe
PostPosted: Wed Feb 25, 2009 3:44 pm
my sami was schedule 40 handrail, i rolled it several times and the cage never moved a 1/8th inch haha but its HEAVY.
PostPosted: Wed Feb 25, 2009 8:02 pm
thanks for the imput
any comments on seam tubing?
PostPosted: Wed Feb 25, 2009 8:06 pm
Ya, don't use it.
PostPosted: Wed Feb 25, 2009 8:13 pm
All jokes aside ---take a piece of 11/2 seamed tub and a piece of DOM put them on the ground hit it with a hammer the dom is much harder to bend flat .I build my C.D. out of dom
PostPosted: Fri Feb 27, 2009 4:30 pm
atleast use dom around your head and body and erw for the rest just to be safe unless your life is worth saving a few bucks jmo
aaron
PostPosted: Fri Feb 27, 2009 5:17 pm
yea i wasn't recommending it just saying.....but i bet that sammy cage was tougher than my rail frame that almost guaranteed
PostPosted: Fri Feb 27, 2009 7:25 pm
Wall thickness and diameter also are factors to consider you could use erw in 120 wall @ 1.75 for the mains and drop back to .095 wall for secondary members. just remember your getting older less flexible and you heal slower than you used to?
PostPosted: Fri Feb 27, 2009 7:47 pm
I made my suspension with DOM tubing but both frames I have owned from Berrien and Beeline were both ERW 1.5"x.095. I would bet all those Beeline Cobras running around the woods aren't DOM. Brace it and weld it correctly and I don't think ERW is a problem. I personally would not use chromolly. I don't have enough experience welding it and I do know it can be very brittle if overheated. I would rather a tube bend any day before it just shears. Just my 2 cents. If you can swing it use DOM, but don't think it to be necessary.
PostPosted: Fri Feb 27, 2009 8:46 pm
Chrome-Moly is stronger than DOM and DOM is stronger than ERW
ERW stands for Electric Resistance Welded. This is a mild steel tubing that started out as a flat sheet of steel, formed into tubing and welded. DOM stands for Drawn Over Mandrel and it is actually ERW tubing that has gone through a second process that shapes and smoothes the tubing so that the walls are more uniform. This in turn makes the tubing stronger than the original tubing. Chrome-Moly is an alloy of steel which incorporates both Chromium and Molybdenum in the process. Please don't confuse Chrome-Moly with Chrome finish
What type of tubing should I use in the manufacture of my roll bar or cage?
All street roll bars are made with DOM. Race roll bars are made with DOM tubing for cars under 3500 pounds. 2" x .120" ERW is used for cars weighing over 3500 pounds. Street/Sport bars are made with DOM tubing. Roll cages are made with DOM tubing.
PostPosted: Fri Feb 27, 2009 8:54 pm
All true, but most recrational "play" buggies of the type we run are .095 wall 1.5 od erw. So anything more is a step in the right direction?
PostPosted: Fri Feb 27, 2009 11:39 pm
correct......
PostPosted: Sun Mar 01, 2009 11:48 pm
ive been talking with some dirt track drivers and they are saying they r using 083 dom for their entire frame.
i was going 2 use 095 but all the local steel companies seem 2 be out of it so im thinking of just going with 083.surely if its strong enough 4 a late model or modified race cars it should be enough 4 a buggy.??.
PostPosted: Mon Mar 02, 2009 12:43 am
braced correctly yes. most are halo style single cages also.
