It is currently Mon May 04, 2026 11:17 am
 Post subject: front bumper
PostPosted: Mon Feb 02, 2009 8:31 pm
I have my bumper all tacked up. Before I weld everything I was wondering what you guys think. All I have to say is all the mutable angles were a bitch to figure out. Also I bent everything with a cheap bender and sand. It worked out pretty good. Any suggestions welcomed.
I don’t know if I should add this brace for more strength or leave it out for an easier spot to hook a strap to.
 Post subject: Re: front bumper
PostPosted: Mon Feb 02, 2009 9:03 pm
Looks great to me, are you going to cap the ends? Maybe move thoes 2 supports away from the end some, enough to hook a strap onto it.
PostPosted: Mon Feb 02, 2009 9:08 pm
It looks really good. I used a similar design and added tubes across the top of the bumper linking the top loop to the main cross bar. I think it looks good with and without it. I also had a second cross tube but I think that would get in the way of your winch fairlead.
PostPosted: Mon Feb 02, 2009 10:35 pm
Right on brother... Burn it in!
Hello, this is America. Please press 1 for Spanish, press 2 for Chinese, press 3 for English...
PostPosted: Mon Feb 02, 2009 11:33 pm
brad if you need to bend stuff bring it over and use the bender. just finished my new front bumper 12 lbs lighter then the old one
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Feb 03, 2009 10:04 am
Looks good. You do not want the cross bar hanging out there with out the brace. It will bend real easy in an Impact.
PostPosted: Wed Feb 04, 2009 10:23 am
looks badass brad. I see ol' blue on the floor, lookin sexy
PostPosted: Wed Feb 04, 2009 7:10 pm
looks good.
PostPosted: Tue Feb 24, 2009 1:56 am
Got the bumper done I moved the gussets in like Mike suggested for a strap spot.
PostPosted: Tue Feb 24, 2009 9:27 pm
That looks a hell of alot better than the one the PO had on it!!
aaron
PostPosted: Wed Feb 25, 2009 5:59 pm
bumper looks good but I really dig those shock towers gives it a nice desert racer look
