It is currently Tue May 05, 2026 2:01 am
Post new topic Reply to topic  [ 143 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: started on new buggy
PostPosted: Fri Jan 09, 2009 9:04 pm
Odyknuk you probably have one of the safest buggies in the woods looking at the pictures. I have run mesh in 4 of my last 5 buggies and solid in 1 I just like the mesh better . I understand sticks can come in on you but If you dont run side panels I dont see where a solid floor is that much safer
PostPosted: Fri Jan 09, 2009 10:13 pm
instigator wrote:
Do what you want with the floor its yours theres pro and cons to both. i myself have mesh so i can see through it while in a wheelie. just my .o2 worth. Same goes with hard tops its like placing a snow sled on top of your buggy.it will protect you from sticks but it will also help the buggy slide all the way to the bottom.
PostPosted: Thu Jan 22, 2009 1:18 pm
wile waiting on my funds to build back up and some frontend parts to get here I started cutting my tiresImage
PostPosted: Fri Feb 13, 2009 5:28 pm
Allright time for a update :D
PostPosted: Sat Feb 14, 2009 6:04 pm
well I have been unable to log on for the last 3 days
True roller ImageImageImage
bought K-Babys engine Image
having to cut out fuel tank bar can some one say DAMITImage
PostPosted: Sat Feb 14, 2009 9:13 pm
take you a hammer to that carb and *%#$%%^
HOLD IT HOLD IT
I lost my mind for a sec
man don't that suck I have had that happen alot
to me :roll:
good luck
PostPosted: Sat Feb 14, 2009 9:43 pm
try an offset intake,is the other side ok?
PostPosted: Sat Feb 14, 2009 10:51 pm
that thing is bad a$$!
PostPosted: Sun Feb 15, 2009 9:32 pm
Very nice. I really like the extra bar you added to your roof!
Bryan
PostPosted: Mon Feb 16, 2009 2:25 pm
That looks great. Bryan will be happy that it is finlly going to be finished, instead of in his barn.
PostPosted: Mon Feb 16, 2009 10:32 pm
thanks guys ............It is starting to look like some thing other than a big pile of parts
PostPosted: Tue Feb 17, 2009 5:13 am
Buggy looks great. I have a solution to your fuel tank bar problem. Notch the bar so the air cleaner clears & use a piece of steel pipe with an inside diameter a little larger than the air cleaner to bridge the gap. It will look like you made it that way on purpose without the rework.
PostPosted: Wed Feb 18, 2009 9:52 pm
got roof tabs shift rod gard for rear passanger and put it back togeather to run brake and clutch lines will put roof on friday and shocks are on the way in the big brown truck also got tank moved ImageImageImage
PostPosted: Wed Feb 18, 2009 10:05 pm
Man I really like that buggy! Awesome!
Bryan
PostPosted: Wed Feb 18, 2009 10:06 pm
SWEEEEEEEEEET !!!!!!!!!!
PostPosted: Sun Feb 22, 2009 6:45 pm
got shocks in and on 1 side front and rear (i know they aint FOX ) but they will do for a trail buggy !
PostPosted: Sun Feb 22, 2009 8:33 pm
tell brandon we need to see some pics of his buggy now,and what kind of shocks are those?
PostPosted: Sun Feb 22, 2009 10:27 pm
I will tell him , he is going to bring up to my shop to do a few thing to it and I will get some photos then
The shocks are Bilstien 5150 piggy backs 12" on back 10 " on front
PostPosted: Mon Feb 23, 2009 9:29 pm
got roof on after work today wont be long til paintImageImage
PostPosted: Tue Feb 24, 2009 1:12 pm
Nice lookin car! Whats the wheelbase?
PostPosted: Tue Feb 24, 2009 8:15 pm
thanks
it is 108"
PostPosted: Tue Feb 24, 2009 10:17 pm
Looking real good. I really like the way the roll cage is braced up. I wanted to do something similar on mine however like a lot of things I ran out of time.
PostPosted: Wed Feb 25, 2009 5:52 pm
hillaholic is this what you had in mind ? I had to use 1" for clearance for the tie rods I am going to brace the shock towers also but ran out of tubingImageImage
PostPosted: Wed Feb 25, 2009 5:57 pm
Yep,,those are a must,,,found out the hard way myself :oops:
PostPosted: Wed Feb 25, 2009 6:30 pm
That thing look's good Ilike alot of the things you did to it.I also have 1 seat in the back for my boy. he's going to be 10 in april and i guess i'll start building his then, but when he was little i bought one of those simpson baby seats at wal- mart. it was awsome already had 5 point belts fit him good from when he was 18 months until almost 4.just thought i'd let you know i seen you said you had a 18 month old.on my new buggy i took a plastic welder from harbor freight and cut down a high back poly seat to fit back there and still look like the front seats. was amazed how easy and nice of a job it did.but anyway can't wait to check out the final pictures when you get it done.gasman :mrgreen:
cron
