It is currently Mon May 04, 2026 5:20 am
 Post subject: New Build
PostPosted: Sat Feb 21, 2009 6:15 pm
I am building a new buggy from scratch. Following is an initial list of parts I have compiled. If anyone can think of additional items please let me know. ie: missing parts, must have items, cool ideas, wish list items. :?
    Frame
    Front bumper
    Rear cage
    Grab bars
    Foot bar passenger
    Pedal mount
    Tree bars
    Tow hooks
    Solid trans mount
    Storage box/ map holder
    GPS mount
    Cup holders.
    Fuel tank / storage area
    Floor
    Rear skid pan
    Mounting/floor tabs
    Dzus fasteners
    Side panels
    Fire wall up front
    Hood
    Fenders
    Fender mounts
    Windshield
    Top side curtains
    Rims
    Tires
    Zerk fittings
    Front beam
    Front trailing arms
    Front thru rods
    Front spindles
    Front bearings
    Front suspension bushings
    Front brakes
    Front shock mounts
    Front shocks
    Front bump stops
    Rear trailing arms
    Rear CV joints
    Rear drive flange
    Rear axels
    Rear stub axels
    Rear bearings
    Rear suspension bushings
    Rear Brakes
    Rear shock mounts
    Rear shocks
    Rear limit straps
    Rear bump stops
    Pedal assembly
    Brake lines
    Clutch line
    Accelerator Line
    Parking brake
    Shift lever
    Shifter box
    Shift shaft
    Turning brake
    Fire extinguisher/mount
    Front seats
    Rear bench seat
    Front seat belts
    Rear seat belts
    Battery box
    Battery
    Key set
    Speedometer
    Oil pressure gauge
    Fuel gauge
    Temperature gauge
    Tachometer gauge
    High beam indicator
    Console
    Map light
    Switches
    Fuse block
    Head lights
    Desert Head light bar
    Desert Head lights x 4
    Front blinkers
    Rear blinkers
    Large back-up lights
    Brake lights
    Rear running lights
    Rear view mirror
    Side mirrors
    Wiper assembly
    Steering wheel
    Steering shaft
    Steering shaft mount
    Steering knuckles
    Steering rack and pinion
    Steering tie rods
    Steering tie rod ends
    Bar padding
    Winch
    Exhaust
    Fuel pump
    Transmission
    Clutch
    Ignition coil
 Post subject: Re: New Build
PostPosted: Sat Feb 21, 2009 6:21 pm
All you need now is alot of time and a fully stocked cooler!! :mrgreen:
PostPosted: Sat Feb 21, 2009 7:08 pm
Maybe an engine,,,Subaru of course,,,,and a tow strap to pull your buds with :mrgreen:
PostPosted: Sat Feb 21, 2009 7:40 pm
haha your funny,me and bobby may ride saturday to try out bobbys new motor and my new frame
PostPosted: Sat Feb 21, 2009 8:30 pm
no suby motor and sounds like your building a street machine.
PostPosted: Sat Feb 21, 2009 10:10 pm
gas tank?
cool stickers?
Preferably hot passenger?
excess funds?
are just a couple you forgot.. :lol:
PostPosted: Sun Feb 22, 2009 10:41 am
It will be street legal. Already have a 2332 VW. Mid travel for the woods of northern michigan and out west in utah and colorado. 3x5 arms 6 inch wider beam longer front trailing arms Coil over race runners already purchased. Frame is a Berrien Sand Fox 4x modified by Dan Beaudoux.
PostPosted: Fri Apr 03, 2009 8:50 pm
Thanks for posting the shopping list for me Jesse.
I will be making a custom tank, no on the stickers but will have everything powder coated, my wife is smoking hot (just ask me anytime), excess funds are a little hard to come by these days that is why I purchased the frame a year ago and have only just started the main build. I did go with a 2332 VW engine and built that last year. We skipped the cooler and went right for a brand new kegerator.
As soon as I take a few pictures I will post them.
Bryan
