It is currently Mon May 04, 2026 8:59 am
 Post subject: wanted bus
PostPosted: Fri Feb 13, 2009 6:15 pm
I am looking for a bus torison and a bus transmission and axles everthing to switch from swingaxle.in the in the east tn area peferabley thanks.
 Post subject: Re: wanted bus
PostPosted: Fri Feb 13, 2009 6:21 pm
run a car torsion. much softer.
"Lets go get stupid"
PostPosted: Fri Feb 13, 2009 6:40 pm
by all means use a car torsion
PostPosted: Fri Feb 13, 2009 7:08 pm
but if u want i can hook u up with bus torsion 6 rib and axles 650.00 straight out of the bus...
PostPosted: Fri Feb 13, 2009 7:25 pm
so what i really need is just a irs car torsion will the bus axles bolt right up to that. I have a old irs car torsion i guess i just need trans and axles thanks guys
PostPosted: Fri Feb 13, 2009 7:42 pm
did'nt you say it had a swing axel in it :?: if so, weld some irs piviots in shortin the spring plates and your ready to go. Swingaxels had soft tortion bars if I remember right
PostPosted: Fri Feb 13, 2009 7:53 pm
how much do i need to shorten them and do i just weld the pivots right on to the torsion itself. prob sounds dumb to u all this is my first rodeo with a rail dont know alot bout them thanks
PostPosted: Fri Feb 13, 2009 7:59 pm
you can get pockets at any buggy shop Tim Deaton prob has them at Southern buggys
they set against the frame horns where the trany sets you can also get a bug to bus conversion kit from him and get trailing arms from our CEO D.Marks then you set
if it were me I would go with 3x3
PostPosted: Fri Feb 13, 2009 8:29 pm
[quote="bradley59dzl"]but if u want i can hook u up with bus torsion 6 rib and axles 650.00 straight out of the bus...[/quote]
if you need a torsion i have one with dbl spring plates boxed trln arms with newer disc brakes
PostPosted: Fri Feb 13, 2009 10:08 pm
how much do you want for it and excatly were are you located?
PostPosted: Sat Feb 14, 2009 10:59 am
if u buy it with a trans an axles take 900 for everything
271 petersburg rd
enon valley pa 16120
right on pa ohio line
